mce076
its a little hard to describe but i'll give it a shot "thumbsup"Keep it up, looks better and better every update "thumbsup"
Can you show a pic or describe the "quick release" bonnet system, at the shock mounts and cab area ?
you basically need to start off with a bonnet thats had the hood hinge mod done for the upright shock mount on the Twin Hammers...
that involved cutting a cross bar from the hood piece itself so it could hinge forward towards the front bumper
when the bonnet piece is moved closer to the cab, it can be hooked underneath the bar work thats been left on the cab..
here you can see the V bars on the windscreen come down and the bonnet hooks behind them..
the cross bar has been flipped around so its now in front of the V bars when its original location was to sit behind...
this shows where the V bars come down and join that horizontal cross bar and create a kind of "L" shaped hook on either side...
the front of the hood piece now becomes the hinge point, using some spacers and screwed it to the shock towers..
i had to enlargen the screw holes through those 2 short tubes at the point where the hood would normally attach the front skid/bash plate on the TH
i'll refine the hinge when i get some shock towers made up that suit the now angled front shocks
