Turnigy or MKS HV-767 Servo? Anyone tried?
After waiting over 2 weeks I finally gor my HV-300.
Stall Torque (12V): 38.40 kg.cm (533.3 oz/in)
Got it installed, but won't have time to test for a while. It's def longer than most servos and when installed on a BTA rig will stick out quite a bit.
Which makes it a tight fit
Sorry about the crappy iPhone pics...
Anyways, it is definitely putting out some serious power. I'm running it right off my 3s pack (no BEC). Can't wait to really test it out and hoping for no stripped gears. <knock on wood>
Welp, I killed the one on my rig. The gears are fine, but the motor was not up to task and gave up. I've got a second one in there just incase the 1st one was a fluke, but if that one dies I'm going to want either a refund or credit from HobbyCity.
are you going to try it with lower voltage to see if the failure is voltage related?
Nope, going full voltage again. At full charge the 3s lipo is at 12.6v and when the last servo went voltage was well in the 11s. The rig hit a bind in the steering that the servo couldn't overcome and something in the motor stripped. It made a horrid noise like gears stripping.
If it can't take the full voltage of a 3s I don't want it...:cry:
I've been testing for a few days now and so far it's looking good on servo #2. I'm going to send in dead servo #1 and see what they say.
Hmmm I was reading the reviews on the HK site for this servo. 3 of the 10 reviews were poor saying it died within a day. All the bad reviews were in March 2010. Also, I can't find a gear kit for this servo on their site. One of the reviews said that the gears stripped right out. These are supposed to have titanium gears, so that's pretty supprising. Maybe only SOME of the gears are titanium?
That's funny, I remember leaving that exact review. If you look at that review again, you'll see my celsiusprime signature. I was super excited when I first put this servo in. It was fast and crazy strong. Then, BOOM! Stripped gears...
Good luck on getting a refund or a new replacement. I sent mine in with an RMA and they told me that they don't warranty the servos for stripped gears.:evil: They are now sending me back the broken one and I'm going to attempt to fix it myself.
Yup, same result. The refused to refund me too. I'm having them send my brocken one back also.
My friend stripped his HV300 also and upon closer inspection found the culprit gear. There is a gear that is 2 mated to form one, and it seems they are two different metals (titanium and a lesser and smaller bronze colored gear). The smaller gear is the one that stripped. If you can get that to stop happening by bonding the two you will have a bullet proof servo. My friend has super glued his for now to see how that will hold and so far it's looking good.
I'l hoping this fix works."thumbsup"
You guys can get your gears here. I believe these are the same servos just a different name on them.
http://mars480.com/mksmegesetfo3.html
Had the same problem with the two gears that are pressed together. The upper right gear in the picture. One solution if they are slipping is to flare out the smaller gear so it bites the bigger gear more. I had a small tapered rod that I hammered in from the bottom that expanded the small gear enough to bite. Worked well for a while then the output spline snapped off in a crash. :evil: Again this was with the MKS servo but they look to be the same servo. MKS did have much better customer support and fixed any problems I had. Even called me from Tiawian to check up on things.
Really liked the power of these just wish they were ALL titanium gears. Moved on to a Hitec 7950TH."thumbsup"
anyone know if the mks gears still have the crappy pressed gears my turnigy just started to slip on me after 20 or so packs and lookin for a fix
