Tucky
I’m slowly building this truck and I can’t figure out the understeer problem. It just pushes the front tires and then I end up throttling through the obstruction and get off course. I have 59mm injora shocks with no springs and 35wt oil, injora diamond +4mm axles, rubber band limit strap 74mm DJ crawler tires with solid brass wheels and 72mm injora comp pins in brass wheels and they both do it.
Any ideas on how to fix this?
