Time once again to pick the brains of those experienced with this topic-
I've recently gotten a trailer and will be using my TRX4 Defender to tow it.
TRX4 has the original XL5 ESC with a HH Trailmaster 550 21t and running a HH shv500 v2 if that matters. This rig will be pulling IMO a lot of weight... Trailer is little over 4 lbs and with a 6+ lb Capra on board, that's approx 10 lbs for the TRX4 to pull.
So... What should I do to insure that the TRX4 tow rig will perform at it's best and/ or what should I be concerned about? The stock ESC has been surprisingly reliable in this rig but wondering if it might have issues pulling this much weight around? Also wondering if the Trailmaster 21t should be sufficient and if not... what advice is there regarding a motor upgrade? Lastly I'm wondering about the gearing. Running the stock 32r/ 11p gearing right now. Not sure if there's a better motor and/ or pinion combo out there that would be better. The TRX4 is pretty heavy already fwiw.
Thanks very much in advance. I want to make sure that any potential weak points or sure fire failure points are addressed before heading out to the trails with this Defender tow rig.
