CaptainCalm
So, I'm planning on buying a TRX-4 Defender. I've read that the servo isn't good and that if I change the servo I should really get a BEC. These are the applicable things that I have sitting around already from my other RC cars and helicopters:
My (wife approved) limit is £600 and given the above, my plan at present is to buy the following (prices that I know that I can get them for are in brackets):
For the moment, I'll not be taking it through any water, so waterproofing of the UBEC and bypass cable are not a concern right now. The reason why I'm planning on getting the bypass cable is so that I can use the UBEC to power the steering servo alone, the ESC will still power the RX and diff-lock servos. That way, when I get a waterproof Castle BEC or something, I can up the servo voltage to 7.4V whilst keeping the RX and diff lock servos at 6V.
On the servo front, I'd rather stay with Savox since I've been really pleased with them and not had one fail on me yet.
Here are my questions:
- An old unused Overlander UBEC (4.8/6v selectable, 3A continuous, burst 5A)) which I'm figuring should do the trick temporarily if I select 6V.
- Gens Ace 2s 1800mah hardcase lipo (Deans)
- Gens Ace 32 2200mah lipo (Deans)
- TRX-4 Defender (£517.50)
- Savox 2210SG (£76.49)
- Male Deans to female Traxxas TRX connector (£2.59)
- Rx bypass cable (£6.99)
- Metal servo horn (£7)
- Does the above sound reasonable?
- Given my current budget, have I missed anything, or is there anything that you'd do differently with good reason?
- I'm really concerned about the low voltage detection on the XL-5 ESC, what is the cutoff voltage? Does it auto-detect 2s/3s and cut off appropriately? Would you suggest I use a separate low voltage alarm?
