Scott Tighe
Just picked one up, thinking about some brass up front. Any other mods people are suggesting? I use it for a trail truck with some light crawling. Eventually I’ll get beadlocks with some hyrax tires as well
An overwhelming amount of threads on this but...
Keep any added weight down low as possible... c-hubs
/ carriers, portal covers, diff covers, and other brass parts are the normal starting point but I wouldn't go crazy by throwing a bunch of brass at your rig. Also there can be compatibility issues from one manufacturer to another so keep that in mind. A rig that is too heavy will suffer performance loss just as one that is too light. Also, try not to add weight above the frame rails... keep it low, towards the front of the rig, and over the axles.
Not sure what battery you're running but I'd also try to get away from Traxxas batteries. They're way overpriced and with their connectors; will limit you from running other batteries. I like the XT60 connector as do a lot of others. If you can solder that's gonna help. Or you can also run Traxxas to XT60 adapters from your stock ESC to accommodate other batteries. Traxxas lipos are big, heavy, and expensive. Going with a smaller 2S or 3S will get rid of some of that top-heavy weight as well.
I'd run the stock XL5 ESC for as long as it works for you but I'd seriously consider going to something like a Hobbywing wp1080 ESC down the road. They're inexpensive, better quality-wise, and have a lot more tuning options/ settings than the XL5.
I wouldn't look at ANY Traxxas brand servos as an upgrade to your steering servo ( and that stock Traxxas servo probably isn't going to last long fwiw). But there are a ton of great and affordable options if and when the time comes that you want to upgrade that Traxxas 2075/ 2075X. Traxxas servos are junk. Tons of decent quality servos out there that won't break the bank. Just gotta watch running some high torque servos with the XL5. Direct power servos are also an option if keeping the XL% or you could run and external BEC. Lotta different options there.
I wouldn't replace the Traxxas GTS shocks since you're talking about upgrades. Traxxas did a great job with these stock shocks... I'd keep em.
Other than that there's an endless lot that you can do to the rig but don't go overboard... There's no need and a lot of the cool looking stuff out there isn't going to do much performance-wise and may wind up being money unnecessarily spent. Save it for a nice set of bead-locks and some good tires.
Any company that makes reasonably priced brass parts that fit the trx 4 ?
