snydas1987
Hey so I'm going with 1/8 ifs/irs electric racing buggy or truggy as my base chassis to build off.
I'm going to run 3.2 panther paddle tires on beadlock rims, so I'm.not sure if a buggy would handle the bigger wheels in strength and gear ratio wise. Plus the truggy will have longer wheel base and be wider so more stable I think. Is this the direction I should go?
I also need to be able to run higher diff gears in the front axle than in the rear (so overdrive front diff ratios), either be able to buy diff lockers or just JB weld the diff gears so its locked.
And I'll want to be buying aluminum front and rear suspension control arms, and stainless steel screw/bolt kit.
Brushless motor and ESC combo, not sure if I need to run a high torque motor or high speed racing motor. What's your advice?
Then I'll run a ford bronco 1/8 body and a custom made tube rollcage to mount body on. Still using the complete truggy or buggy chassis(which ever you think is best, plz give me your advice)
I'm going for the full scale white ford bronco FOFf rig you see on Google n youtube.
I'm also going to run a real v8 engine sound box system for realistic engine sound as I believe that's the best part of foff, that high powered engine hauling are up sand cliffs.
Thanks guys hope you can give me your best advice as to the base rig I should build of - buggy or truggy?
Snyds
Snyds
