Traxxas TRX4 Front Electronics Tray by Crawler Innovations
Nova's Ark
Tire&Foam Extraordinaire
Subscribed Member
C.I. Compound, Tyler, Texas
Crawler Innovations bolt on electronics tray for the front of the Traxxas TRX4 scale crawler. The tray is cut from 1/8th black delrin for strength and durability. The purpose of the tray is to move the electronics to the most forward location to increase front weight bias for competition RC rock crawling. The front part of the tray can serve as either a small battery mount, or the knock out plate can be removed to allow for a standard size servo winch. The electronics plate is cut to accept a standard Velcro battery strap. The rear of the plate extends towards the transmission along side the motor to allow for esc or receiver mounting. This electronics plate installs by removing the factory servo screws, feed the steering servo lead through the opening in the plate, and then re-install the factory bolts. This product is made in the U.S.A.
One Tray is $14.95
#crawlerinnovations #rccrawler #traxxastrx4
An over due update on our Traxxas TRX4 that is set up as more of competition rock crawler. The build thread for this truck can be found here:
http://www.rccrawler.com/forum/traxxas-trx-4/584796-ci-unboxes-trx4-traxxas.html
Vanquish Products / Incision Method 1.9 MR307 bead lock
Pitbull Tires 1.9 Braven Tires
CRawler Innovations Lil Nova Foams:
CWR-2092 Front = 4.0" / Medium Outer
CWR-2093 Rear = 4.0" / Firm Outer
Traxxas 3.5 Big Bore shocks P/N 2660
Jeepindoug Mini T spring Cups
Losi Mini T front spring set
Jeepindoug 5mm ball studs
The rear bumper was created by my son Gavin of Ayala Metal Works:
Castle Creations One Cell ESC
Castle Creations BEC
Tekin Gen3 13.5 sensored brushless motor
Hitec 7954 steering servo
Futaba 4PK tx & rx
4S Lipo
Crawler Innovations TRX4 Front Electronics Tray CWR-5015
My son Gavin of Ayala Metal Works created the ultra simple and strong front bumper:
Another view of the electronics:
A better view of the Jeepindoug 5mm Ball Studs:
Underside view:
This view is to show the underside view of the installed CI electronics tray:
Value Hobby 4S 1600mah lipo battery:
More wheel, tire, and foam goodness.
Crawler Innovations Lil Nova Foams:
CI traded for this second TRX4 sometime ago. It needed some assembly and electronics. Here it is next to The Ferd;
Pretty straight forward;
Vanquish Products 1.9 KMC Enduro XD222 bead lock wheel
Vanquish Products KMC Enduro 1.9 beadlock ring black anodized
Pitbull Tires 1.9 Rock Beast original
Crawler Innovations 4.50" Lil Nova Foams; Comp Cut;
P/N CWR-2025 front; CWR-2026 rear
CI acquired the 2nd TRX4 so that it could be used with our Traxxas TRX4 Front Electronics Tray; P/N CWR-5015 pictured with a servo winch installed:
Installed electronics in the 2nd rig as pictured are:
Hitec 5645MG servo
Castle Creations Sidewinder ESC
Castle Creations 10A BEC
35T brushed motor
Vanquish Products - 1.9 OMF Bead lock w/ IBTR rings
Pitbull Tires - PBX A/T Hardcore
Crawler Innovations -
Lil Nova 4.0 Standard / Medium Outer CWR-2092 Front
Deuce's Wild CWR-3006 Rear
Same truck, no real updates to report other than the wheel tire and foam change. On to some current pictures taken at Barnwell Mountain ORV park.
The brass parts are holding up well:
The TRXFERD pictured with "The Formula" a 2.2 competition truck build:
Gavin on the rocks at Barnwell Mountain;
