Hello,
I am starting a sort of crawler project. Its more of a scale project than a performance crawler, but since I am interested in makeing it as capable as possible within the scale apperance I will be posting questions about it as I go along.
My first problem is the transmission.
THis is a simplified tranmission showing just the gears and their interaction (shafts ect are left out). The pinion and spur are undetermined. I am unfamilure with the dynamics of the rather large tires that are used, so I am unsure what kind of final drive I will need. I am assuming that a gear reduction (before the pinion, such as the GD-600) is most likely going to be needed to turn the large tires.
THe pinion and the spur gears are pitched differently than the rest of the transmission.
Will I be able to get proper gearing without the GD-600 with a large spur and a tiny pinion? Or will I have to work the gear reducing gearbox into things?
Thank you,
Greg
Thank you,
Greg
