C*H*U*D
No idea what I'm doing
Why is therea prize, if so I did.:ror:
Pics or you're lying! :ror:
I go make one.:ror:Pics or you're lying! :ror:
Hey Juan...what tooth count count do you have on the bandsaw and what rpm?
Im running about the same speed but I use an 18tpi blade...I keep meaning to finish the shoulder of mine to have full circle support of the foam as its cut...maybe Ill do that this weekend and repost pics...Hey Thomas,
The blade in the pictures is just a metal cutting blade with 10 TPI. I run it at 330 FT/min.
I think the trick is to have the edge of your fixture as close to the blade as possible. I actually thought about having another piece of wood on the other side of the blade to provide support to the foam. I may make another fixture someday for my bandsaw at home.
Wow, I just cut some foam strips on my band saw and I never would of guessed it would of cut that smooth and clean.
An electric carving knife works great on foam too.
Really old thread, but a cool idea. I wonder if these could be cut on a woodworking bandsaw that runs at a minimum of 1500 FPM? My only other option is a metal cutting bandsaw that runs between 78 -180 FPM.
