C*H*U*D
No idea what I'm doing
Wasn't sure if this should go into "Tires and Wheels" or "Tools and Procedures".....since it is technically a tool I stuck it here, but Mods feel free to move it if you like.
I've searched around and didn't find anything on any type of foam fixture so I hope this isn't a repeat.
I've been running HB Rovers for awhile, and although I really like the tires, I've always thought the foams were just way too soft for my terrain. Where I work, there is a lot of open cell packing foam so I decided to do some experimenting with what I had available.
My first attempt ended with a few "round looking" foams, but I really wasn't happy with them. So I decided to make a fixture for our bandsaw that allowed me to make a truly round foam. This is what I came up with:
This is some of the foam we have laying around. It's probably too stiff, but better than what I had originally.
First thing to do is cut out a square that is larger than the diameter you want.......rough out the center with a Sharpie and drill out the center with a hole saw. I'm using one that is close to the size of a 2.2.
I put these edge pieces on that helps locate the fixture against the blade.
Then it's just a matter of putting the foam over the rim, and sliding the fixture into place. Then rotate the foam around the rim while the blade cuts it.
It also works well for trimming off a thinner piece for making dual stage foams. I just trimmed this one down......I really want to find some of the pink foam we have laying around.
For my last set that I just made, I wanted a slight chamfer on the outside of the foam. I used this angle plate to make a smooth chamfer around the outside of the foam.
Hope this helps someone.
