cyborgx
Hi there,
In my work building a custom 2.2 pro crawler, I have stumbled across an issue with the electronics. I use a Futuba 4PLS with a R304SB-receiver together with two Holmes Hobbies BR-Mini ESCs, two servos and two 10Amps BECs (using 4WS).
It seems that there is problem with the throttle. Now and then motor that is connected to channel 2 on the receiver gets a "kick" (just as if you hit the throttle unintentionally) for whatever reason I cannot figure out. And without me touching anything, of course.
I've tried to switch ESCs connected to channel 2 (where the problem seems to be), and the "kick-effect" moves from one motor to the other. Channel 4 (the other ESC-channel) seems to be fine, and the motor connected to this isn't affected by the same, uncontrolled "kicks".
Does anyone have any idea to what might be causing this behaviour and what to do to eliminate it? Electronic disturbance from motors/ESC? Bad connections?
