(Note: If this needs to be moved please let me know, its a scaler, but also a MRC!)
So, anytime I am at the thrift stores I always roll over to the toys to see if I can find something cool to play with. I ran across this beach toy that looked very close to a Jeepster so i had to have it! Originally inteded on making it a small r/c crawler and started searching around for axles that would fit it well and I found out the Losi mini Crawler was just about the right dimensions for this little guy. Eventually fond a MRC on the local craigs list, it was actually a stock parts rig assembled from all the stuff the previous owner swapped out and upgraded, so I ended up with a complete roller for $50! I plan on swapping the wheels from the stock 1.9s to a more fitting 1.5 wheel/tire combo for better scale looks. Currently working on a custom tuber style chassis for it, its my first attempt at brazing so its taking a minute to get used to it, but coming along well I think. Well, here it is:
When I first picked it up:
Lowered it and stretched the wheelbase for an idea of where I wanted it to sit
A little detail in the interior already, but will probably be detailed more in the future
Started pulling it apart to start the modding process
Plastic is nice and soft so it was easy to do some trimming
Does anyone else still draw? Figure everyone else uses CAD these days... and this is a 1:1 scale drawing of the Jeep itself, actual size! it fit on an 8.5x11 piece of graph paper!
Day I picked up the parts rig
Stripped down and ready for lots of mock-up and visualization
Looking decent, the Losi was more than a perfect size for this thing, wanting to go with 1.5 wheels and tires though
Good amount of room under the hood on this guy, hoping to get the trans, steering, and electrics under here...
Made a carboard frame from the dimensions on my plans so I could be sure it was going to work out, drew up the plans quite some time before getting the donor rig
Trimmed out the passenger seat to make room for the frame and rear suspension
Made custom links using the standard method
Made a rear axle truss that will also serve as a upper link mount out of 1/4" square brass
Did another for the front that will also be the shock mounts
Getting there...
Started on my framerails using the same 1/4" brass as the axle trusses, the square was a little difficult to bend, and it kinked in a couple places. Should have filled it with sand to help prevent that
Using the stock skid for a transfer case mount and LCA mounts, trimmed down the stock frame plates to drop iy away from the floor of the Jeep to make room for the TC
I should have enough room in there
So here it sits, still have much to do, including getting rid of that cage and brazing my own!
Getting there...
