Pics above show approximate body placement.
Today I figured out a simple way to mount it.
Details are in the Pics.
But to sum it up. 2 screws in the front bumper/servo mount hold the front of the body center. These holes were in the perfect spot once I moved the mount back a bit into the chassis rails, to catch the inside corners on the RC4WD body at the front. The body has 3 tabs hanging down to mount the front bumper, which I am not using. I removed the center mount to allow it to pass down in front and up against the steering servo. This allowed the front of the body to sit flat on the front bumper/servo mount. In the rear, I used the 2 short RC4WD Body mounts, trimmed them down by removing the bottom hole and stem of the mount, then used a screw through the rear bumper with a nolock nut to make a spacer and move the body post in a little on each side lining them up with the 2 rear holes in the bad of the Blazer body, which allowed me to use 2 clips to secure the back down, while tightening the 2 screws in front holds the body down up front.
Only thing left to do as far as body mount and being a ready to run rig (barring all thebody work I want to do) is to either heat and bend up or flare out the front lower fender areas, or just trim them out, which is what I am leaning towards now. A trim would look decent enough for a redneck like me, lol.
But to do it the way I want, I'll need to pick up a coping saw. Otherwise, it's loaded and cocked. Just need to make room for those front wheels and Its on to use and body details.
Shitload of Porn for your viewing pleasure.
How the front screws are used to hold the body down and tight. I will likely add a washer just to grasp more of that part of the body to secure it better.
Couple pics of the rear under the body
Rear bed body posts and clips from inside the bed area
