KRAWLR4life
Hey guys, thought Id share this lil' GEM with you!
I just got the SSD-RC High Ratio Trans kit (Part No. SSD00016) and
I cannot believe the quality of this transmission for the price you
payfor it! :ror:
I got this trans for my U4RC 2.2 Trophy class rig, I like the ideal
of getting a little more wheels speed without adding more motor or
over gearing.
This High Ratio Trans comes almost complete, so its considered a 'kit'.
You can either strip your old Wraith tranny for the parts
needed to complete it or just buy a few new parts for it and save
your old trans, that's up to you!"thumbsup"
I went ahead and built this trans with new parts, I'll add the needed
part numbers below for anyone who wants to built it new!
It is recommended by SSD-RC to run the under drive gears (43/13T)
in the front and rear of your axles to obtain optimal gearing and very low torque twist.
The stock Axial trans ratio is 2.6:1, this SSD-RC trans ratio is 1.8:1,
it should help out the top end speed!
Another AWESOME feature to this trans in the 3MM think motor plate!
Its think! Your not stripping anything on this motor plate!
Once I get this trans installed into my U4 rig, Ill test it out and let
you all know how well it holds up, I will be testing it in the most
harshest of RC environments.. U4RC Racing!"thumbsup"
All greased up and ready to build!
Its a work of art! :mrgreen:
Parts needed to build a complete trans from this kit:
Stock Axial transmission input shaft (AX30198 or AX31149)
Stock 20T drive gear (AX30162)
Stock Axial transmisison idler shaft (AX31090)
Stock Axial transmission gear cover (AX80078)
Stock Axial slipper clutch assembly
Bearings needed:
(4) 5 x 10 x 4mm
(1) 5 x 11 x 4mm
(1) 8 x 16 x 5mm
(1) 15 x 21 x 4mm
Thanks SSD-RC for yet another great product!!!
Click here for more info! HRT KIT
payfor it! :ror:
over gearing.
Bearings needed:
(4) 5 x 10 x 4mm
(1) 5 x 11 x 4mm
(1) 8 x 16 x 5mm
(1) 15 x 21 x 4mm
