Comp rigs are a special breed. They are built and designed to challenge the status quo, fight gravity, and put a smile on the face of the driver and spectator alike. Scalers can't do what comp rigs can do, and because of that, comp rigs will never die.
This truck has been in the planning stage since last year. The parts and time finally came together and here is the Crawler Innovations Double Agent.
First and foremost, a huge Thank You to my sponsors on this build:
Holmes Hobbies
Y Town Crawlers
Vanquish Products
Links:
Rod ends
Set Up #1
Set Up #2
Set Up #3
Set Up #4
Axles:
Specifications:
- Axial XR-10 Axles
Front axle Upgrades:
VP Ti Steering Link
Crawler Innovations Engraved Servo Guard
Axial Machined Gear Set - Full
Axial Titanium Top Shaft
Rowdy Racing Battery Tray
VP Aluminum Case Top
VP Aluminum C - Hubs
VP Aluminum Steering Knuckles
VP Aluminum Motor Plate
VP Aluminum Transmission
VP Upper Link Mount
VP XR-10 Knuckle Weights (modified)
Rear upgrades:
VP Aluminum Lock Outs
VP Upper Link Mount
Shocks;
Front:
3.5 Traxxas Big Bore
3 Hole Piston
15 Weight Oil
JeepinDoug Mini T Spring Cups for 2.2
Mini T Soft front springs
Shock Cap Mod
Limited Internally 6mm
Rear:
3 Hole Piston
25 Weight Oil
Shock Cap Mod
Chassis:
Y Town Crawlers, Carbon Fiber, Double Agent
Skinz:
Custom Made by Freq-E-Tag Designs
Links:
Chaotic Crawler Titanium Lower Links
Lunsford Straight Titanium Uper Links
Electronics:
- Hitec 7954 Steering Servo; programmed
- Holmes Hobbies Smashed BRXL Mini's ESC's
- CC BEC; programmed to 7.4 volts
- Holmes Hobbies Motors:
2 x Holmes Hobbies 16T Hand Wound
Battery:
850mah, 30C, 3S, Align Lipo
Pictured Wheel, Tire & Foam Set up;
Front:
CI 6 Bolt Wheels
HB White Dot Rover sanded, siped & grooved combined with a HB Red Dot Block Truggy Tire sanded, siped & grooved
CI Double Deuce Foams;
5.5" Comp Cut Inner
Soft Outer
350 SLW Hub
Rear:
CI 6 Bolt Wheels
HB White Dot Sedona sanded, siped & grooved combined with a HB Red Dot Block Truggy Tire sanded, siped & grooved
5.5" Comp Cut Inner
Soft Outer
600 SLW Hub
Holmes Hobbies
Y Town Crawlers
Vanquish Products
Links:
![14656899995_679b483422_o.jpg](/forums/proxy.php?image=https%3A%2F%2Ffarm4.staticflickr.com%2F3881%2F14656899995_679b483422_o.jpg&hash=78a80bdd10f0a752475219210754db0a)
Rod ends
![14633937376_53f0ab59e7_o.jpg](/forums/proxy.php?image=https%3A%2F%2Ffarm6.staticflickr.com%2F5481%2F14633937376_53f0ab59e7_o.jpg&hash=291a5441cb263ab7be5a4b86a787e406)
Set Up #1
![14470478817_9b74c4d361_o.jpg](/forums/proxy.php?image=https%3A%2F%2Ffarm6.staticflickr.com%2F5577%2F14470478817_9b74c4d361_o.jpg&hash=140fc93c332e1814f687d3f5a9874ab4)
Set Up #2
![14470277859_3e65ae6966_o.jpg](/forums/proxy.php?image=https%3A%2F%2Ffarm4.staticflickr.com%2F3897%2F14470277859_3e65ae6966_o.jpg&hash=21dcb2fc4d86d67711fd1497996f7381)
Set Up #3
![14676822083_835b1ba2b9_o.jpg](/forums/proxy.php?image=https%3A%2F%2Ffarm3.staticflickr.com%2F2918%2F14676822083_835b1ba2b9_o.jpg&hash=79284419fcb852c428355298e2299ad2)
Set Up #4
![14656898005_45260dd36f_o.jpg](/forums/proxy.php?image=https%3A%2F%2Ffarm4.staticflickr.com%2F3850%2F14656898005_45260dd36f_o.jpg&hash=3f4679f013b8bc4f92466ef1133f2f72)
Axles:
![14676823723_b5a2f1c0c7_o.jpg](/forums/proxy.php?image=https%3A%2F%2Ffarm6.staticflickr.com%2F5522%2F14676823723_b5a2f1c0c7_o.jpg&hash=9adf3b9964109444133570a6a471d5c1)
![14470230190_0911c5b8dd_o.jpg](/forums/proxy.php?image=https%3A%2F%2Ffarm4.staticflickr.com%2F3897%2F14470230190_0911c5b8dd_o.jpg&hash=2a58a705db40e139bfb1affab31677c2)
Specifications:
- Axial XR-10 Axles
VP Ti Steering Link
VP Upper Link Mount
Rear upgrades:
VP Upper Link Mount
Shocks;
Front:
3 Hole Piston
15 Weight Oil
Shock Cap Mod
Rear:
3 Hole Piston
25 Weight Oil
Shock Cap Mod
Chassis:
Skinz:
Links:
Electronics:
Battery:
Front:
CI 6 Bolt Wheels
5.5" Comp Cut Inner
Soft Outer
350 SLW Hub
Rear:
CI 6 Bolt Wheels
5.5" Comp Cut Inner
Soft Outer
600 SLW Hub
