Very few original parts, perhaps some of the chassis, in the current setup almost everything has been replaced and adapted to run on medium and high difficulty RC trails.
//Motors , Radio,
[OLD]
-2 Integy 45T motors in parallel at 2s or 3S Lipo. Low power and high torque, very smooth.
[UPDATED]
-1 BL Outrunner Leopard 1720 Kv. + Hobbywing SC8 120 WP
-1 CPU fan 60 mm , motor.
-2 Al heatsinks.
-Airtronics-Sanwa 2.4 3 channels.
//Battery, Charger.
-52000 mah in 12 Lipos 2s/3s. 30 to 50c. Gens Ace, Jamara, Vant,Traxxas, Turnigy
-4200 mah NiMh 9,6 V to power Led lights in emergency.
-*Lipo Battery Voltage display integrated in the rear bumper.
-SkyRc D100, Imax B6 and Digipeak chargers
//Rims and tires, [summer]:
-Axial_ax8046 Beadlock rims, 3.8" 40 series.
-Proline Trencher 3.8" 40 series.
//Rims and tires, [winter]:
-Proline Velocity 3.8" 40 series.
-Proline Moab 3.8" 40 series + chains, nails, extra rubber profiles
//Transmission, Differentials
-Pinion/Spur gear 12/72 [stock 18/66]
-Mip steel Cvd, front
-Traxxas E-Revo style axles and carrier, rear
-Robinson Racing diff gears.
-2 Traxxas diff spool lock.
-Integy Al diff case
//Driveline, suspension
-Rpm arms, front.
-Rpm axle carrier, front
-Rpm Truetrack, rear.
-Hitec 645 MG Servo
-Traxxas Big Bore shocks. 1b position.
-Silicone oil. 50 front, 60 rear.
-Custom dual spring rate, soft 10 mm + hard 55 mm.
-Integy shock spring set Tmaxx -red-.
//Bumpers & Skid plates
-Rpm bumpers
-Custom skid plate ,front
-Rpm skid plate ,center.
-Integy Al skid plate, rear
//Hardware, Bearings
-All external bearings rubber sealed
//Body
-Proline F650 body. Daylight.
-Proline Humvee body , 2 * 7W 12V led, 1400 lumens. Night rides.
