TF2 "Trailblazer" project (rc4wd Blazer)
Will clean the box a bit but you get the idea how it will look.
-Pate
Raised the dash about 8mm and test fitted Fonzie.
Removed his pelvis so he fits,so only minor cosmetic surgery.
The steering wheel was too close to the dash so I used small piece of alloy tube to lenghten the post.
Made few scale thingies.
-Pate
Got new wheels!
The Cepek tires are so soft that they needed some tlc.
I shoe gooed the sidewalls.
It really did help, but few spots it looks like scale sidewall damage.... but nothing too bad and it did help.Still looks like low air pressure but not empty!
Thinking of taking one helper spring off front to drop it a bit.
-Pate
Finished the interior.
May do doorcards some day but I need to finish this and go outside !
Will do rear seat in few weeks(when the mojave bench gets back in stock)
-Pate
Changed the tires to mud trashers.
Also made the wheel wells front and back.
Changed the alloy center plate to much larger styrene piece.
Battery change is simple now, just pop the hood!
Changed the driveshafts to junfacs, all the outdrives neened dremeling but now it works flawlesly :chug:
And the biggest update?
-it runs!
Small teaser clip below
https://www.youtube.com/watch?v=w4VU5cAI10M
about 2 hours of driving and no issues, everything works like it should.(ok, the sidewinder and sound module needs minor tweaking)
-Pate
Still some issues with the sounds but it will be ok soon.http://www.rccrawler.com//fi.pinterest.com/pin/create/extension/
