sean_lv_crawler
VMG TO CRAWLER! by Sean lv crawler
Hi there,
Ok i got sick of posting so many times over and over on how to make a VMG into a crawler. So i am making a tech article for all you people out there. VMG to Crawler!
Here's a list of everything you need.
Tools needed - Dremel, JB weld, hot glue, screw driver....
The dreaded CLICK CLICK CLICK
This noise is GOOD! it happens because there is a gear inside the tranny that has a sring attached to it. When there is too much tension it slips. It is like a slipper gear. If you want to get rid of it. There is a gear that came with your vmg. All you do is open the tranny up and replace the similar looking gear. Be careful you have a chance of striping your gears now but i havent yet
Articulation
The most arc you will need is about 70 degrees. 70 is perfect. You do not need 90+ degrees of arc, that is just stupid. 70 - 80 is good for crawling.
Gear Reduction - Click
(to mount the reduction - Click
Mini Metal Gear Servo - Click
The Servo Saver (need to use screw from hs81 and grind down the sides of the screw to make it fit) - Click
Everything to Get the Servo Mod Done -
Click
Click
Click
Click
Swami Servo Mounts (or you can fab up your own)- Click
Heres a pic of my mounts with everything on.
To Stretch it -
(WARNING - YOU WILL NEED 20 CUPS AND BALLS FOR THIS CONEVERISON! and 22 for 4ws)
4-40 Full Threaded Rod (of course you dont need this many) - Click
Balls - Click
Cups - Click
Metal tubing 5/32 - Click
jb weld - Click
Get Your COG Low!
COG- center of gravity
So what you want to do. Get your battery pack on the rear axle if your not doing 4ws. Then take your reciever/esc unit and put it under the upper plate. Here are some pics. i Hot Glued my Battery and Esc so it would stay.
If you want four wheel steering - Click
Also will need another servo and swami mount
and you will need to use your rear axel diff gears and axels and bearings.
Heres a pic of the way i did my upper link mounts. All i did was take a length of tubing. flatten it with a hammer. Then drill 3 holes. 1 on the left 1 in the middle and 1 on the right. Then use the old screw from the red triangle link to hold it down. pics say a thousand words.
IN ORDER TO DO THE DRIVE SHAFTS YOU WILL NEED TO CUT THE DRIVE SHAFT IN HALF AND THEN USE THE METAL TUBING AND THE JB WELD. JB IT INTO THE METAL TUBING.
If you want 2.2 wheels.
Click
Click
Click
Make sure to lock your diffs. open them up. take out the diff gear. open the diff gear up. take out all the little gears.(SPIDER GEARS) clean off all the grease. then put the little gears back in. Then hot glue the ends shut. Make sure you use alot of hot glue. Then trim if necessary. some people say that locking just the front is better than locking both. i have both locked and i am happy with it. its up to you. hot glue is real easy to undo. just take a flat head and pry off each end of the diff. then peel away. some pics.
Look my toe ^^^
If you want to mount a different body - http://www.carttonic.com/catalog/in...id=466&pi_id=109627&clist=0,11310,89002,90247
Here is how i mounted my mini t extended body posts.
Average price that you will pay to get it to a crawler?
The truck will cost around 100 depending on where you buy it. And all the parts to get it to a full blown crawler will put a whole in your pocket of around 100-150 depending on the 4ws or 2.2's.
Total cost = $250 usd
Here it is all finished. And one heck of an awesome crawler.
Wheel base = 8 1/2 in
center clearance = 2 3/4 in
under axle clearance = 1 in
Here are some comparrison pics from stock and mine.
Here are some vids of my mini giant in action
Click
Click
I want to thank TeamFSU, BlackMagic, and all of www.rccrawler.com and www.one18th.com for helping me.
Hope this gets you far. anything else i think of i will post back up here.
Good luck! God Speed!
