WINNER~~~ TeamNovak Giveaway ~~ Crawler 13.5T BL Motor ~~~
Due to the popularity, and member participation, of our first Novak product Giveaway, we offer our newly-released Crawler 13.5T BL motor. This addition to our motor offerings is geared for those racers looking for a lower wind, more powerful motor:
This offer is valid thru midnight Sunday, August 23, 2009. I will post the name of the winner in this introductory post on the following Monday.
The forum rules are simple:
1. You must be a star-holding member of the site to be eligible for this giveaway
2. Only one post (entry) per member will be accepted
For those wanting to purchase a Novak Crawler 13.5T motor, please check with your local hobby store.
I would like to announce, and congratulate, our new winner---jeepial----
Please PM me your contact and shipping information.
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]CRAWLER 13.5T SINTERED BRUSHLESS MOTOR
[/FONT] [FONT=Arial, Helvetica, sans-serif]Novak’s quick 13.5-turn crawler motor has many advantages. First, the faster speed is ideal for rock racing, where not only agility but speed plays a large part in these events. The Crawler 13.5 motor is also a perfect complement to Losi’s® 1/10-Scale Comp Crawler Race Roller™, and it’s ideally compatible with Novak’s Goat 3S Crawler Brushless/Brush ESC (#3214) when using a 2S Li-Po pack and Novak’s original 2S Li-Po Goat Crawler ESC (#3219).[/FONT]
http://www.teamnovak.com/products/brushless/3419_crawler_sintered_motor/index.html[FONT=Arial,Helvetica,sans-serif]LET'S GET CRAWLING[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]CRAWLER BRUSHLESS MOTOR FEATURES
[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Specifically designed for R/C vehicles that require precise movement control[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Sensor-based technology for excellent low-speed driveability[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]High-strength sintered rotor for unmatched performance[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Oversized Front Bearing for extra durability and extended life[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Aluminum ribbed end bells for additional cooling[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Direct-Solder Wiring Tabs for flexible soldering options[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Minimal Maintenance[/FONT][FONT=Arial, Helvetica, sans-serif]No cogging[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Designed and dyno-tested by Novak in Irvine, Calif.[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]CRAWLER BRUSHLESS MOTOR SPECIFICATIONS
[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Number of Turns: 13.5 (#3414)[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Design: Sensor-based[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Watts: 195 (#3414)[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]KV (unloaded) 3,300 (#3414), RPM/Volt[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Motor Size: 2.08”L x 1.41”D (52.8 x 35.8mm)[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Shaft Diameter: 0.125”; 3.2 mm; (accepts all existing pinion gears)[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Motor Weight: 6.61 oz. (187 grams)[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Bearing: Oversized (1/2” x 3/16”) Front; Standard Rear (3/8” x 1/8”)[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Magnet: sintered Neodymium (one-piece, multi-pole cylindrical high-strength)[/FONT]
