SWB bronco MIP driveshaft issue (supplier Super Shafty)
I have had my RTR bronco for a while now and lost the front pinion driveshaft pin. First issue I’ve had so far after almost 2 years of abuse. So always looking to upgrade to better parts I looked into steel driveshaft upgrades due to the simple fact of changing the pinion input to the 5mm stub for way easier R&R down the road. On RPP Hobby I finally found a set of super shafts MIP HD driveshaft kit for the SWB ascenders.
Order them, also order gcm pinion adapters. get them all looks good. No directions. But seems straight forward. Build them. Compare lengths to originals,
Seems close but one yoke is longer by 4mm than the other 3 shorter yokes. Emailed about location, but while I wait I figured I’d just try them out. After finding some issues I didn’t like in test fitting they seemed to long. So I went forward with install to see if they would even fit.
They won’t. Slip joint is bottomed in lower yoke and axles are rolled at 30 degrees or more with shafts in. Lower links and shocks won’t even mount up due to driveshaft bind. At full droop they are bottomed. No compression for up travel at all. Needless to say I’m dissatisfied. But willing to put in the work if they can make it right. ( I have the K5 ascender also but the time aspect is what I don’t like wasting to trial for them)
Other issues I have found.
1. Cross pins for pinion yoke attachment is very loose fitting. To install you would have to bottom the thread on the pinion shaft to get it snug. Pin diameter is just to small or these two parts are not compatiable.
2.flats on trans outputs and holes one MIP short yokes are not a prefect alignment an set screws will land partially on the flat and partially on the shaft body.
3. Length is obviously incorrect even thought part number states SWB on the package.
4. No directions. (I’m still pretty new at scale crawlers but I do this all in 1.1 for the past 15 years so I’m confident in my suspension setup but this just flat won’t work.)
I’ll work on this issue more later with pictures if I can attach them for future users thinking of going MIP.
Shafts are still to long. Since I bought this ready to run I have no longer links or spacers to try to make it work. I’m thinking since the package has k5 written on it maybe it was a mix up. I also don’t know how long the shafts for this wheel base should be.
I’m going to measure links and check the link length sticky to see what it is. I’m assuming wb1.
https://image.ibb.co/eAxKH0/9-E7-E8999-43-C4-45-F0-A44-C-6537-DA0-F78-C7.jpg
https://image.ibb.co/gRkTAL/4101-FBE8-E27-D-4000-BDCE-D971-AA195-C7-E.jpg
https://image.ibb.co/bypYc0/A4-FB2-C24-651-F-441-F-96-E3-B6-C069-C4-FF57.jpg
That’s the best I can figure out. Not sure how to make them appear in the thread. Idk what HTML is or what type of embedding codes I should be using.
