svt923
Seasons greetings, everyone!
As a very generous and benevolent person, I have an early (or late depending on your winter holiday of choice) present for all.
A new build thread! :mrgreen:
That's right. I, Mr. SVT, am bringing you, the common reader, a fantastic new build thread to read while you count the days until your impending time off from work. Please contain your excitement however, not all are invited to this holiday party. Todd from security won't shut the hell up about his crossfit routine and Patti from HR is always like "you can't do keg stands in the conference room", they are totally out.
So let's get at it. You have that 8th eggnog and belt out "Livin on a Prayer" on the karaoke machine and I'll start with this:
It's a Wraith chassis. Well, a Wraith chassis with a few things done to it. This one has been waiting to get built for a while.
Some not very interesting Wraith stuff has been done on the past: hinged hood, a Spawn interior has been installed, Scorched Parts inner fenders from Shapeways, and some other things that I may get to later.
Now for the part where the whole "not a Wraith" thing comes in. Let's take a trip into the magical closet of wonder:
This is the cabinet about 5 feet from my workbench. I believe this clearly demonstrates I am a complete RC degenerate but this time my unnecessary hording paid off.
Let's try the box labeled "Axles". Yes, I have a whole box of assembled axle sets. Told you there is something very wrong with me.
Ahh, here we go.
A set of built Bowhouse NCX10 axles. For those who are not familiar, these are basically a AR60 shrunk down into a SCX10 sized axle with bigger pinion bearings. The front uses 2 short side Wraith universals, Wraith c-hubs, Wraith knuckles, Wraith link mounts, Wraith diff covers, etc but bolts up to a SCX10. These particular axles were built with Axial HD gears (standard ratio up front, U/D in the rear), Incision lockers, Vanquish clamping c-hubs and lockouts, Vanquish knuckles, SSD diff cover in the front, RC4WD Poison Spider cover in the rear, and a Samix titanium tierod.
These axles were originally from my GCM Skeleton but were replaced by a set of SCXII Curries. I know this is a solid setup.
As I get around to rebuilding thing that were originally built with Lucas green grease, I become less and less convinced that the typical wheel bearing grease we use on our RC gears doesn't do much of anything after a couple runs. Everything was given a coating of Vanquish grease which seems to hold up way better.
While you may be thinking "great SVT, you are building a 1.9 Wraith, why didn't you just say that in the first place?" Don't fret, this is much more than an ordinary 1.9 Wraith. Even if someone has built the exact same truck already, I don't care because this thread is better. Like right now, its already better. There is just a few pictures of a chassis and some axles and my thread is better than the entirety of your thread Mr. "I built that already". So shut your face and let me continue.
Anyway.
Axles - Check
Transmission, hmmmm.
SCX10 transmission is easy but what would make my life more difficult? Oh, I know!
A Bomber transmission. Well, technically this is the transmission from my Yeti that was torn apart to build my IFS Bomber then a Bomber transfer case was added but for simplicity sake, I'll just say its a Bomber transmission.
This particular transmission is still a single speed with a STRC motor mount. I'll probably keep the Holmes 21T 550 motor in there because hurray laziness.
I like to keep a little logic to my threads so if we have a Bomber transmission we also need....
anyone?
A Bomber skid!
Good job everyone, you all make me so proud.
So we are going to throw 3 trucks in a blender and see what comes out. Axial will be so proud of their mutant spawn when it grows up.
On to a little actual building and it only took about 11,000 words to get here. Not bad for me.
I really wanted to get the battery and all the other electronics under the hood so I picked up this Wertymade snub nose electronics tray.
There will be no servo winch on this one so I plan on sticking the receiver and ESC in that space.
Since the electronics tray wants to occupy the same space as the inner fenders, it got sent for a little bench grinder and belt sander therapy. A few MMs were taken of the edge sitting against the fender. More could probably come off but it seems good enough.
A keen eye reader might have noticed something on the front of the chassis in the first pic. Actually, you probably could have noticed a bunch of stuff but I'm going to gloss over 90% of it.
Flipping the truck over, questions are answered or more questions have come up but the important thing is we're talking.
That is a STRC Wraith CMS mount, too bad I installed it wrong. Man, I am bad at this truck building thing.
With the Wertymade electronics tray, the original Wraith radio box isn't needed and wouldn't fit anyway. The mount for the radio box serves as a sort of brace for the front end, well I got rid of that too and made an aluminum brace instead. Who says Axial's old links are terrible? I mean, they aren't very good links but they are super easy to turn into chassis braces. The front end is very rigid now, that is decidedly un-Wraith-like.
I've always been a fan of the Wraith fastback look so some choppy-choppy and a set of Scorched Parts fastback struts later:
A old RC4WD radio box was painted and bolted in to put something in the vast emptiness of the cargo area. I can fit all the scale crap in this one, it will easily be a -180 point truck in all the comps.
So I have laid it out for you: the new build, what is going in to it, what I built with the rest of the Wraith parts. Oh, umm, forget I said that last thing.
Anyway, gotta go and remember to forget.
Ahh, here we go.
Anyway.
Axles - Check
anyone?
A Bomber skid!
