Voodoobrew
I am looking for transmission options the have a lot of reduction to use 3200kv brushless motor in but I still want to crawl slow. Reason being is that the higher rpm and more reduction will give better low end resolution and torque. This is just for technical crawling, I don't intend on driving over 4mph ever. I will have the rear underdriven but I am not using that in calculations because the front will be at this stock ratio. I find that I am always barely touching my throttle and in the bottom 5% of the trigger, simply adding a throttle curve Isn't what I want. This is for pleasure use, not for competitions.
stock axial wraith transmission: total reduction - 35.47:1
12t pinion and 56t spur 4.67:1 ratio, 2.60:1 transmission ratio, 2.92:1 differental. I could fit a 9t pinion and 96t spur on my transmission and increase the reduction to 81.07:1 but thats the max possible I am aware of on this transmission.
What I have found so far:
Hot racing - SCP38X01 Low Cg Transmission Gear Box - Ax10 Scx10: total reduction - 192.53:1
Acording to Hot Racing this has an 11.4:1 reduction in the transmission and a 52t spur. with a 9t pinion (pinion spur ratio: 5.78:1) you end up with 65.78:1 to the drive lines and 192.53:1 at the wheel. This has an optional dig.
RC4WD - AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho: total reduction - 1st gear- 131.21:1, 2nd gear- 46.25:1
with a 9t pinion and 80t spur you get 8.89:1 before transmission, 5.05:1 for 1st gear or 1.78:1 in 2nd gear in the transmission and 2.92:1 in stock ar60 axles.
what other options for low gearing do you know of, and will any of these handle a 3200kv brushless motor at top speeds?
I dont think a planetary gear reduction on the motor is the way I want to go because they all say they cant handle brushless.
On the Hot racing - SCP38X01 with a 5.5 in tire @ 11.1v on a 3200kv motor I expect to get a maximum speed of 3.02mph that is a fairly normal walking pace if the numbers on ther site are correct.
On the RC4WD - AX2 2 Speed with a 5.5 in tire @ 11.1v on a 1700kv motor I expect to get a maximum speed of 2.35mph in 1st gear and 6.67mph in 2nd gear, which sounds nice too.
I used this for my calculations https://docs.google.com/spreadsheet...EjJFcdtjU4hW5xzKsDp01D0a4/edit#gid=1058564524
