buggy0001
I started collecting parts to build a sportsman style crawler and ordered this servo. I then realized that it says its designed to run on a 2 cell lipo. I already ordered a 3s lipo's so will this work?
HS-7980TH High Voltage, Mega Torque, Titanium Gear, Coreless Ultra Premium Servo
Part No: 37980S
<!--sphider_noindex--> <!-- Start Advanced Gallery Html Containers -->
Click image above for full size.
‹ Previous PhotoNext Photo ›
Additional Views
HS-7980TH High Voltage, Mega Torque, Titanium Gear, Coreless Ultra Premium Servo HS-7980TH High Voltage, Mega Torque, Titanium Gear, Coreless Ultra Premium Servo HS-7980TH High Voltage, Mega Torque, Titanium Gear, Coreless Ultra Premium Servo HS-7980TH High Voltage, Mega Torque, Titanium Gear, Coreless Ultra Premium Servo
<!--/sphider_noindex-->
Product Description
Hitec's strongest servo period, the "Monster Torque" HS-7980TH is designed to operate on a two cell LiPo Pack. Featuring our newest high resolution "G2.5" 12 bit generation programmable digital circuit and our indestructible Titanium gears, The HS-7980TH has the performance and durability you've come to expect from a Hitec servo. Other features in the HS-7980TH include a 7.4V optimized coreless motor, integrated heat sink case, and a top case with two hardened steel gear pins supported by axial brass bushing.
Applications for the HS-7980TH include high performance Giant Scale Aircraft, Truggies and Buggies, Fast Power boats, the largest aircraft, monster trucks or anywhere else you can use 600+ inch ounces of torque.
Features
Specifications
<TABLE style="WIDTH: 100%" cellSpacing=0 cellPadding=0 border=0> <TBODY> <TR style="BACKGROUND-COLOR: rgb(102,102,102)"> <TD>Motor Type:</TD> <TD>Coreless</TD></TR> <TR style="BACKGROUND-COLOR: rgb(133,133,133)"> <TD>Bearing Type:</TD> <TD>Dual Ball Bearing</TD></TR> <TR style="BACKGROUND-COLOR: rgb(102,102,102)"> <TD>Speed (6.0V/7.4V):</TD> <TD>0.20 / 0.17</TD></TR> <TR style="BACKGROUND-COLOR: rgb(133,133,133)"> <TD>Torque oz./in. (6.0V/7.4V):</TD> <TD>500 / 611</TD></TR> <TR style="BACKGROUND-COLOR: rgb(102,102,102)"> <TD>Torque kg./cm. (6.0V/7.4V):</TD> <TD>38.0 / 46.0</TD></TR> <TR style="BACKGROUND-COLOR: rgb(133,133,133)"> <TD>Size in Inches:</TD> <TD>1.72 x 0.88 x 1.57</TD></TR> <TR style="BACKGROUND-COLOR: rgb(102,102,102)"> <TD>Size in Millimeters:</TD> <TD>43.69 x 22.35 x 39.88</TD></TR> <TR style="BACKGROUND-COLOR: rgb(133,133,133)"> <TD>Weight oz.:</TD> <TD>2.70</TD></TR> <TR style="BACKGROUND-COLOR: rgb(102,102,102)"> <TD>Weight g.:</TD> <TD>76.54</TD></TR></TBODY></TABLE>
Part No: 37980S
Additional Views
Product Description
Features
- G2.5 12 bit Digital Programmable Circuit
- Titanium Gear Train (MK first gear)
- Ultra Performance Coreless Motor
- Integrated Heatsink Case
- (8) O-Rings for Water/Dust/Fuel protection
- Dual Ball Bearing Supported Output Shaft
- 10% larger than a HS-7955TG
- Dead Band Width
- Direction of Rotation
- Speed of Rotation (slower)
- End Points
- Neutral Points
- Fail Safe On/Off
- Fail Safe Point
- Overload Protection* (default is off)
Specifications
