I ran into this exact same issue while building up my SCX10ii. A wire extension will work, but that leaves you with another connection that needs to be sealed to waterproof it. Or, you can also get a 300mm servo wire and replace the existing one. Yes, it's more work than just plugging in an extension, but you maintain a simple waterproof connection. The servo wire comes complete with connector installed and ends stripped & tinned. Carefully open the servo case, remove the "guts," and unsolder old/resolder new wire. (Don't forget to feed the new wire through the servo casing BEFORE you solder it to the board, like i did. D-oh!) Reassemble. Reinstall. Run it!!
Aside from my goof of forgetting to run the wire through the case, it was a fairly simple job, and works perfectly!
Edit: 300mm servo wire:
https://www.rpphobby.com/ProductDetails.asp?ProductCode=SPMSP3004
