STANG KILLA SS
~THE SCALE SHOP~
so scale and clean!
bigger bearings, built in link mounts (no hardware showing) , true centered upper link mounts, minimized lockouts, and a removable front 3rd member!
DIAMOND CENTERED REAR AXLE FOR AXIAL WRAITH (BLACK)
FEATURES
<!-- content --> CNC machined aluminum axle case
Annodized Black
One piece main housing design with removable third member
Diamond style with integrated upper link mounts
Centered gear housing
13mm diameter axle tubes
Hardened steel axle shafts
Larger input pinion shaft bearings
Fits stock lower link mounts
Fits stock Axial gears
Same width as stock AR60 axle
Direct replacement for Axial AR60 rear axle
Suitable for Axial Wraith, Yeti and AX10
WHAT'S INCLUDED
<!-- content --> Complete aluminum axle case (black)
2 * Axle shafts
2 * 5 x 13 x 4mm bearings
HARDWARE
<!-- group --> <!-- content --> M3 x 25mm button head
4 * M3 x 10mm button head
4 * M3 x 6mm button head
10 * M2.5 x 6mm cap head
FEATURES
Annodized Black
WHAT'S INCLUDED
2 * Axle shafts
HARDWARE
