Soldering ESC and motor
Hoyle
Michigan
Hey all, I just started my first crawler build - bought a HW 1080 ESC and a HH 550 21T brushed motor
Should I solder the ESC directly to the motor, or use bullet connectors?
People on Facebook suggest using connectors so I can disconnect/reconnect easily, but I never really do that on any of my other RCs
And if need be, I can use my soldering iron to disconnect them
Thoughts? If you think I should use connectors, suggest a male/female pair that I can buy
It's fine if you don't mind busting out the soldering iron each time you change the motor.
Just make sure the wires are in the right position for the motor rotation you need.
I had to reverse my motor wires when I first installed that same combo in my Bomber
Sent from my Pixel 2 XL using Tapatalk
Is it common to change motors often?
If I ran a brushed motor I probably wouldn't solder it just so I could carry a cheapo spare and swap it easily on the trail if need be.
I use 4mm bullets, makes it easier to change the motor and to reverse the rotation if needed.
Sent from my Pixel 2 using Tapatalk
You can go either way, it is all up to what you like. Some of us are constant tinkerers, and are continually swapping stuff around, so bullet connectors work for us. If you are not one of those guys, then solder it up and call it good.
This is my first crawler, and I'm not using it for competitions, so I think I will be good going this route.
If I change my mind in the future, removing a solder connection takes about a minute :mrgreen:
Where I usually run is almost always muddy and wet. Every two runs or so someone is toasting a brushed motor and doing a trail swap.
Depending on where you run, I'd suggest using bullets and carrying even a cheapo spare motor like a rc4wd with possibly even spare pinion attached.
If mud and water kills a motor that fast, should I look at a brushless system instead?
That seems kind of crazy to burn motors up that easily.
It will kill a brushless just as fast if you don't do any kind of maintenance...
Clean, dry and lube the bearings after any water, mud or heavy dirt run
If you have to solder bullet connectors onto a new motor you don't save any time. If you have a portable soldering iron you can change motors on the trail too.
It's all preference.
I solder whenever I can. Less chance of anything going wrong on the trail.
I had the same question when I installed mine and ultimately I chose to install an xt60 connection. I used a black xt60 connector to differentiate it from the battery connector. Like already mentioned just make sure you get the polarity right. Have fun!
Sent from my SM-G973U using Tapatalk
Another vote for bullet connectors. Makes on trail repair easier. I’d prefer not to solder on the trail as the bench setup works much better.
Any more details on your setup that makes soldering a motor and esc on the trail just as quick as plugging them in? Very curious about this.
If you use bullet or any other connector vs direct solder you could have your spare motor connectors pre-soldered. That would make for a quick trail swap if needed.
