So So "SEXO" build
sic1to
The Garage!!!
I have wanted to do one of these to change it up a lil so here goes. I posted here because its wraith base with exo cage! The parts list...
Almost new assembled exo kit
Wraith kit(new)
Rx8
Pro4 4000kv
Savox servo til i get HH swapped over
Cc bec
HH bypass adapter
CI elec tray
VP trans case
SS 6mm extended outputs
SS motor plate
RR trans gears
56/12 gearing
Mip's with SS exclusive rear shaft
Front hd gears(front axial universals)
Rear hd underdrives(stock rear shafts)
HH lockers
VP bearing caps
Stock rear truss
Dinky rc servo/truss mount
VP scale chubs
RC bros extended ackerman steering arms
XR10 knuckles with rear arms shaved
VP knuckle weights(modded)
Beef Tubes up front
SSD titanium steering link
Chaotic Crawlers bent titanium links
DCW rear upper link risers
Dlux sway bar
VP black XD wheels
CI dw foams with r35 bfg's
Big bores with rpm dual stage pistons & wicked wolf cap mod
4" rear 31/2 front
Wertymade stinger with integrated sliders
The donor
Other parts
Tubes...
Stock battery tray cut a lil & mounted
Thats all on the building for now, i will be testing this rig this weekend hopefully? It really seems to be a great start with cog & wheelbase at high speeds around the house but it will hit the rocks & trails to see where it needs improvement"thumbsup"
About time Tom!!!!!
The front wrap around cage is Killer! I might have to look into something for mine...
The key function, for me, would be for a winch.
Let's see some outdoor pics!
Ty Troy! I like how it adds strength in the front. I plan to add a winch just gotta figure out what type winch & a way to mount it...any ideas? I hope to get out Sun with a few guys to see what it can/cant do? Outdoor action pics will be a must"thumbsup"
I got my hands on a servo winch. They can be mounted in the chassis and the line ran thru a tube of some sort, to get it to the front/fairlead
I was just looking at it & looking at making alum plate for rear to mount winch & use 3/16(or smaller dia tube) brake line with flared ends to the fairlead?
A lil testing today...
I had a blast with this thing! Only noticed torque twist & i need to change rear shock pistons to allow more oil to pass thru!!!
Everything held up...til i got home for inspection.
I do think I can handle those two lil issues:lmao:
The SEXO was impressive at high speeds & jumping with mild crawling today! Gonna hit the rocks testing at local comp spot soon...
Got any updates on this beautiful sexy beast. Still rockin the brushless? And how has the ssd tie rod held up?
I'm in the process of building up something similar, thanks for the pics
SSD holdin up with no issues! Brushless tekin 3500 56/12 & its dialed in with great bursts & smooooth botyom end"thumbsup"
