TITANIUM94010
Sorry for the bad wording, but does anybody know of a small "transfer case" that lets you toggle between connected and neutral?
Something that goes between a transmission, driveshaft and a diff,
So in the "locked"setting, the transmission sends power to the driveshaft, to the "unit", to the other driveshaft and to the axle.
And in the "neutral" setting, the "unit" stops power from going to the axle and leaves the front axle freewheeling
Power transmission In "locked" position
Transmission---->Unit---->Axle
Power transmission in "neutral" position
Transmission>Unit-----X-----Axle
I'm using it for a custom 2wd/4wd setup. The transmission is a RC4WD AX2. unfortunately, something like the SSD locking hubs wont work, as I'm using a custom mounted Slash 4x4 front IFS, and not a normal crawler axle.
Thanks!`
Edit: If it makes things more clear, I'm trying to find something that will let me toggle between having power being sent to the front axle.
Thanks!`
