Stray
Hello team,
I am scratch building a vehicle with a Wraith transmission. I purchased the main body which came with the trans case, internal gears, and top shaft. To purchase all the additional slipper parts here in AUS is about $35! (plates, spur gear, spring, back plate).
My question is, is there a cheap way to set up a 32p spur gear? I am not actually fussed about the slipper, if I have to have it, ill crank it right down anyway.
the top shaft that came with the transmission is for the newer dual plate set up.
thanks for your help and input!
