1rcmonster
I ordered a Slide-in camper kit from Speedweigand the other day and it arrived..."thumbsup"
First thing I did was lay out all the parts and figure what went where. Once I had it all figured out I labeled each part to aid in assembly. Here is a pic and my list..
#1 Base/bottom
#2 Front wall w/window
#3 Side walls (2 pieces)
#4 Over-cab piece
#5 1" x 7 1/2" piece (goes between #4 & #6)
#6 Front/top angle w/window
#7 Roof
#8 Rear wall w/door
I dry fitted all the parts and then proceeded to gluing them up.
Starting with part #1 glue #2 to the front, in front of #1 and flush with the bottom. Then I attached one side #3 to 1 & 2 and repeated for the other half. I held it all together using Frog tape. When I was happy with the fitments I laid a bead of glue on the inside seams.
Now waiting for glue to dry...
#1 Base/bottom
#4 Over-cab piece
#7 Roof
#8 Rear wall w/door
