westers151
Hi
I'm new to the hobby, and my grasp of the tech side is on the steep side of the learning curve.
One of the areas that I've been reading about (and doing a lot of searching,) is the benefits of shortening the wheelbase to improve the crawling capability.
Now then, in the threads I've read there's a lot of talk about using the shorter Wraith/Yeti trailing arms, but no mention (that I can find,) of how everything else at the back of the chassis needs to be modified, hence I'm asking for simple, clear guidance on this aspect.
My current thought process is as follows: If I use shorter trailing arms, that brings the rear axle closer to the body, and thus the rear bent links, the rear drive shaft, and the rear sway bar all have to be shorter. Is that a correct, logical deduction? If it is, is the answer as simple as use Wraith/Yeti trailing arms, rear bent links, and rear drive shaft, or is it more complex?
Thanks
Thanks
