NCT_Guy
I have been building my Wraith and have taken it out a few times over the course of the upgrades and just trying options to get good control over my rig plus articulation to maintain the tire grip..
First I started out stock RTR set up and then I changed out the springs to a softer rate - It made the truck handle alot better I felt, not so tipsy and the truck sat lower due to me setting the coil preload just tot the point the spring didn't move loose at full extension.
Next - Currently I just installed:
- Level 3 lowering kit.
- ProLine rear Slash shocks front and rear.
- ProLine spring tune kit with the softest rate spring with the transfer turned over.
- 20wt oil
Proline rear Slash shocks are the same length as RTR factory Wraith shocks and with the lowering kit I can bottom out the rear axle upper link mount to the batt. tray and or bottom part of the roll cage. In front I came close to the servo hitting the cage. BUT other wise I really thought the Wraith handled the rough terrain and obstacles really nice at a decent more aggressive pace. Large rock or wood logs was a lot easier than before. Slow crawling pace I felt I lost too much total drop out and could have gained more traction, reason for exploring possibly longer shocks.
So my thoughts as, what about a longer shock that allowed for more travel, loose alittle over all compression travel as I can't use it anyways with the suspension bottoming out now and gain back the full drop out travel as the suspension had from factory that I lost when I lowered it with the new lowing upper shock mounts.
I looked around and found some shocks ranging in 108mm, 124mm and 128mm.
What is everyone else running and or tried on their Wraith, please share set ups and thoughts.
Thanks!
- 20wt oil
Thanks!
