I've been in and out of RC for years and am getting back into it now that my son is old enough. In the last 3 years I've gone down the rabbit hole of mountain bike suspension tuning. They can be very complex systems with orifice dampers, shim stacks, air springs, coil springs, bladders, Internal floating pistons...you name it. I understand suspension pretty well for a layman.
Now that I'm back into RC, I'm puzzled at how little suspension tuning carries over to these. Typically you start with your spring (air or coil). The goal is to get the right spring rate so the vehicle isn't too wallowy or too harsh. Then you move on to damping. Rebound first, then compression (Low speed and high speed).
RC shocks are pretty simple. They have a coil spring and a single orifice damper that is for rebound and compression (both low speed, no high speed circuit).
With crawlers I often see people adjust the fluid weight to compensate for stiff shocks or as they add/remove weight. That does sort of help, but ultimately it sounds like a spring rate issue.
I see times when people use lighter fluid when larger holes in the piston would probably help more. Why? Larger holes allow more flow (same effect as lighter fluid) but would remain sensitive over bigger hits that could otherwise choke the small hole. Orifice damping is very sensitive to shaft speed. At a certain point when the force/speed of the shaft gets too high, the hole is too small and the shock gets much stiffer. So if you want to keep the shocks active and plush, bigger holes in the piston would help more than lighter fluid.
Has anyone played with piston changes and fluid changes in combination?
Oh, and anyone ever compare fluid viscosity across different fluids? Viscosity is what matters and you'll find one 10WT is another's 15WT.
Anywho...Its probably just easier to throw in lighter fluid and call it a day. Or is there some other reason?
