AsILayDying
Well Im in need of a High Torque servo (thanks djblaugh, lol) and I figure why not get something EXTRA strong this time. Go for broke on this one. It will have a CC BEC wired direct to the Servo and the ESC will be a HH BR-XL or a CC Mamba Max Pro. Anyone have any suggestions as to which would be better or is there an alternative that is comparable to the two above. Thanks for any help, info or advice. Need to order or purchase ASAP by like tomorow night at the latest so I could have it by this coming weekend comp. "thumbsup"
Hitec Servo HS-7980Th : 155 dollars.
•6.0V 7.4V
•Speed: 0.20 sec 0.17 sec
•Torque: 500 oz/in (38 kg/cm) 611 oz/in (46 kg/cm)
•Dimensions: 1.72 x 0.88 x 1.57" (43.69 x 22.35 x 39.8mm)
•Weight: 2.70oz (76.54g
Savox Servo 2270SG : 150 dollars
•Dimensions: 40.3x20.2x38.5mm
•Weight: 69.0g
•Speed:
•@ 4.8V: .19 sec/60
•@ 6.0V: .15 sec/60
•@ 7.4V: .12 sec/60
•Torque:
•@ 4.8V: 291.6 oz-in
•@ 6.0V: 347.2 oz-in
•@ 7.4V: 444.0 oz-in
•Gear: Unique Steel
•Bearing: 2BB
•Case: Full Aluminum
•Output Shaft: 25 Tooth Spline
•6.0V 7.4V
•Weight: 69.0g
•Speed:
•@ 4.8V: .19 sec/60
•@ 6.0V: .15 sec/60
•@ 7.4V: .12 sec/60
•Torque:
•Gear: Unique Steel
•Bearing: 2BB
