Servo for 2 speed gearbox
cooper_xl
Portugal
I had this RC4WD Helios 2 speed transfer case for a while now:
It is kind of big for most of my builds but now I think I've found the perfect spot. The thing is that I need a servo for shifting and I can't use a standard sized. What much torque should I be searching?
I mean, I've shifted og traxxas Emaxx transmissions with a standard plastic gear servo, and everything i own that has the ability to "shift" doesn't require a lot of torque to pull the shift fork. I'm thinking a small metal gear servo $10 will suffice.
I've got the agfrc b13dlm for shifting in 2 rigs. No trouble from either. I tried the Injora micro servos in my Phoenix to shift the twin. Also no trouble from those so far. I like that the Injora servos is a standard 25t spline instead of the smaller diameter most micros use but, being injora, I tempered my expectations. So far they've worked fine.
I also have an nsdrc micro that stopped working right. Seems to be a loose wire going into the case as I can hold the wire certain ways and it'll work. I didn't get it handled before the warranty period and I don't really feel like spending half the cost of the new servo to ship it and have it repaired so it just sits in the tool box.
Thanks for the quick reply. Can you provide the model name of the Injora? Injora must be the easier to get here, between your suggestions
