tgenial58
Hi!
I builded a shafty with a semi rigid frame.
the front axle is mounted with fix links.
I have fixed gearbox and motor inside the frame
transmission shaft is a solid axle screwed between axle and gearbox.
I can unmount front axle without get out gearbox of the frame
When i look at the rules, for me, this is a MOB.
Is it ok to pass technical control in crawler comp?
Thank you
Thank you
