Scx24 tegu not working
Afterbang
Golden
Hey guys.
To start, a little back story. My stock motor stopped working. I saw a video on YouTube, of a guy checking his esc to figure out which failed.
I tried the same thing and my probes touched.
I replaced the motor(it was burnt) and I put in a tegu esc. It worked great for a bit, then the scx24 sat for a bit.
Now to my problem. It worked when I unplugged it and it sat for a bit. I plugged in a battery and it wouldn't move. I opened the app, and I can see the esc responding to the throttle, after messing with it, i got the motor to respond, kind of. Forward throttle, makes the truck go backyard, very very slowly, I have also plugged the motor into another esc and it works fine.
I can't reverse the plug because of the spine on the plug, and it worked great before it sat. The wires aren't loose, because it works fine plugged into a different esc.
Any ideas, fellas?
Sent from my SM-G975U using Tapatalk
No the issue is that it only goes backwards and very slowly. It doesn't move forward at all. And I know the motor is good because I plugged it into my other scx.
I got the little guy working today. I updated the firmware from 1.24 to 1.21 I know it's backwards, but it worked.
