Scx24 esc
I’ve used it in a wpl and it worked good. One of them I had was a bit jittery but the other was great
I guess I can always try it and if it doesn’t work right I can always return it. One good thing with buying from amazon.
Buy a furitek esc problem solved! You want 4wd steering buy a spektrum dx5c or DX5 Pro like me and you can set up rear steering from transmitter, it has channel mixing and you can customize a dig profile
I know Furitek has gotten a lot of hype lately, but I gotta also say that I think it’s worth the $ even for a brushed motor setup.
I ordered the whole kit from Furitek, some parts are back ordered but they sent me the Lizard esc ahead of time. For fun I put it in with the 050 barrage type motor and DANG if it isn’t a much better drive than the stock esc. Way better throttle modulation, no torque stall=smooth tire spinning no matter what angle/resistance. It also seems like the motor is running cooler, though I haven’t tested properly. I’m looking forward to the full surpass type install, but this is very much a satisfying upgrade over stock.
