Mods, one of the things I'm still not clear on about the forum is it organization.
Hence I'm not exactly sure if I should post this here or in the SCX10 forum.
So, if I've posted this in the wrong place please feel free to move it or let me know and I will edit it.
With that said here my question/issue....
My Wrangler G6 has developed a "shake" or a "wobble" in the rear.
While its not a obvious as it is when you see it in person, if you watch the attached video you'll see what I mean...
Whats happening is this. at partial throttle (the low end of of the throttle range) the rear wheels shake. It almost like they are skipping. As the throttle increases, from about mid-range on, the rear runs smooth.
The front end mean while is smooth throughout the entire throttle range.
This is a newly developed problem, I've got maybe 8 -10 hours on the G6 and this just started with the last pack I ran through it a week or so ago.
I've taken the pinion off and spun the drive train by hand, both front and rear are smooth at any speed I can spin it at by hand. The motor also runs smooth with or without the pinion attached. The transmission by itself is also smooth with not drive lines attached.
Here's the set up...
Batt: 3S
ESC: Tekin RSX
Motor: Tekin ROC 412 1800Kv
Trans: all metal gears (Robinson as I remember)
Spur: Robinson Racing metal spur and slipper assembly 48 pitch/88 tooth spur.
Pinion: Robinson 48P 16 tooth hardened steel
Drive Lines: MIP front and rear
Diffs: Axial OD front UD rear
Axels: Front Vanquish CVD's Rear: Axial HD stock
Ax Housings: SSD D60 front and rear
I've checked the sensor wire to make sure it hasn't come loose. Also there's not noise that usually occurs with cogging and would the front end would be affected as well if there was cogging.
I've checked the pinion bearings. While it's pretty obvious the pinion bearing won't last long due the angle and the amount of slop in the drive lines for now they are still smooth.
A side question why don't manufactures that make housing not use a bigger bearing, I think that would make the pinion bearing life longer.
Anyway, I've checked everything I know to check to diagnose the problem.
FWIW... it worse with a smaller pinion. I went down to a 14 tooth pinion to slow the G6 down and get a more torque. However, the rear bounce was mores pronounced and was through the entire throttle range as well.
Here's the video..
<iframe width="1280" height="720" src="https://www.youtube.com/embed/DFAmNqciCHE" frameborder="0" allowfullscreen></iframe>
I went through the throttle range up and down in the video.
You can see the front is smooth and the rear bounces at low throttle going up and down the range...
My only thought at this point is the difference in wheel speed due to the OD/UD diff gearing. But that really doesn't explain why it gets smooth in the upper range of the throttle, nor why it wasn't doing this from the start.
I'm hoping some of you guys might have some ideas what might be causing this..
Thanks for your help.
Batt: 3S
ESC: Tekin RSX
Here's the video..
