Westside Charlie
I've been reading a lot of posts about the reasons that the front wheels/axle may chatter or shudder especially when starting to accelerate and the two causes seem to be:
-- drive shafts not aligned properly so that pins are parallel (matching notches)
-- angle from axles to motor too steep
My drive shaft alignments are fine (checked them five times.) I am guessing that my problem began when I replaced the Axial stock shocks (90mm) with Integy Piggyback shocks (107mm). That difference may have increased the angle enough to cause the problem. Prior to swapping the shocks, there was no drive shaft issue.
So, to flatten the angle, I need to clock the axles a bit, right? If so, does that mean replacing my current links (aluminum, so they're good and rigid) with shorter links? I think I just need to point the axle down a scooch towards the motor to straighten out the drive shafts a bit.
Is this a good approach and method? Other ideas?
Thanks!
Thanks!
