xjman
I've got a SCX 10 I picked up some years ago and beat to death for a while. I got side tracked when I killed and and started messing with some 1/5 scale stuff and finally made my way back to the truck.
Basically as it sits it is a rolling chassis. No electronics, beat plastic parts. I see they now make a new version, with newer transmission, non plastic linkages, sleeker new axles. Is any of that direct swap? If not it isn't a concern.
My real targets are links, axles, shocks, maybe tires, and electronics.
What are you guys using for water resistant/proof setups. I was going old school and wrapping my ESC and battery in a balloon and sealing the end with silicone. I would also like to go brushless this time around. I typically float around 55 or 45t motors, for the torque, control, battery life. I'd like to find a comparable brushless. I've been messing with gas stuff so long now, I've not kept up with anything on the electric side of things.
As far as the mechanical parts go, I've used various 1.9" tires this set the RC4WD IROC's seem as nice as the others, but if there is something out there that looks just as nice that performs better I'll be willing to slap them on. Mainly forest floor type stuff with a few creek beds.
Do we have vendors that sell link kits now or are the axial brand ones the really only option, I thought about making a set at work, but I run a lathe 7 days a week and would just like to avoid spending any more time doing it. What about shocks you guys like? Over the years I've tried several brands, and the best I've ever had were stock team associated plastic bodies. They wont work for this application, so what is your favorite?
As far as the axles, I've replaced the rear one a couple times as I've stripped it out, or broken one of the shafts. Are the newer ones any more durable, or is it worth looking at an rc4wd setup?
I'd like to make this fairly scale this time around and not RTR scale. I've had huge failures in the past, so figure why not try to fail a little less this time.
TL
R
My SCX10 has been shelved for a while. Looking for your preferences of 1.9" tires, stock length links (including steering), shocks, and a brushless equivalent for a 55-45 turn motor with matching water resistant speed control.
Any opinions welcomed.
TL
