Is it just me or has anyone else had this issue... Keep in mind my Gen 7 has very little use, in fact I was testing it in my basement when I came upon it. I noticed that the screw that holds the top of the shock to the chassis is SELF THREADING into a pre-drilled nylon hole. Every single other screw on the Gen 7, RS10, and Everest have a nut to hold any load bearing screws to the chassis. Needless to say one of the shocks just randomly popped off the chassis at this failure point. When I tried to re-attach it the nylon hole was stripped. No I did not overtighten any screws. After inspection I noticed that the other three shocks were loose at this same point and the joint flexes considerably when the shock is pressed. It's just a matter of time till the same thing happens to the other three. Furthermore, the screw appears to be just a little too short to even make it all the way through the nylon mount. Am I missing something here or is this a horrific design flaw? I don't recall making any mods to the shock location on this truck but maybe I did and don't remember (has happened before :mrgreen: )
All of this being said, I would like to purchase some new longer screws and nuts so I can mount the shocks properly so they will not fail and fall out. I have a question... what type of screw holds the shock to the body of the vehicle? I'm referring to the black screw that goes through and mounts the ball joint that the upper joint of the shock rotates on. Is there an identification for the form factor for these screws (diameter, thread size, etc?) I think pretty much every single screw on the Gen 7 and RS10, Everest that has has a nut fastened on it is this type.
Thanks!
Thanks!
