Scale truck and crawler tires comparison chart
Sylvain
Canada
We have built a list of the most popular tires used for crawlers and scale trucks with diameters and width->
http://www.myrcbox.com/?p=4322
Some information is missing but we are currently completing the list as we found information.
Hope this may help you!
guess you havent seen THIS STICKY??
http://www.rccrawler.com/forum/showthread.php?t=3992
dont see the sizes of a tire? add it!
dos anybody ever even look or search any more??:roll:
Yeah, but if you know a specific size you're looking for on a build, the chart lets you quickly go to that by scanning down the column. Whereas, with the sticky thread, you need to scan through each tire to see what size they are.
Nice job "thumbsup"
Yes I have seen the sticky but it seems to be more oriented for monster truck tires, just few scale/crawler tires on page 3.
Did you notice when it was created? 2004! That's all we had back then. Folks that came into this hobby after 2007/2008 have been spoiled!
I know and the goal of my post was not to discriminate the sticky. It is complimentary information.
The other sticky is out of date and as said this chart is easier to compare everything against each other. Sylvain has made this up to date and easy to read, I think a replacement sticky is in order.
Agreed.... but in order to be a true replacement means the info needs to be on RCC rather then having to slick a link and go away from RCC. If a sticky is on RCC, the info should all be on RCC.
Just my opinion.
I like the added info.
That's for sure toyo, I remember having to make axle mounted steering mounts for my TXT. All you Noobs have it so easy. Honestly I miss those days, but having all the tire choices is great.
RC4WD 1.55" tires added....
If you wish, you can sticky everything below....
Original website -> http://www.myrcbox.com/?p=4322
1.55″ Tires:
Product Inner Diameter Width Outer Diameter
RC4WD Desert King 1.55 1.55″ (39mm) 1.29″ (33mm 3.66″ (93mm)
RC4WD Dirt Grabber 1.55 1.55″ (39mm) .98″ (25mm) 3″ (78mm)
RC4WD Mud Hogs 1.55 1.55″ (39mm) 1.37″ (35mm) 4.27″ (108.5mm)
RC4WD Mud Slingers 1.55 1.55″ (39mm) 1.37″ (35mm) 4.13″ (105mm)
RC4WD Mud Thrashers 1.55 1.55″ (39mm) 1.33″ (34mm) 3.74″ (95mm)
RC4WD Rock Crusher X/T 1.55 1.55″ (39mm) 1.33″ (34mm) 3.74″ (95mm)
RC4WD Rock Stompers 1.55 1.55″ (39mm) 1.25″ (32mm) 4.13″ (105mm)
RC4WD Rocky Country 1.55 1.55″ (39mm) 1.14″/29mm 4″ (104mm)
1.9″ Tires:
Hot Bodies Rover 1.9 1.9″ (48mm) 1.9″ (48mm) 3.7″ (95mm)
Hot Bodies Rover-EX 1.9″ (48mm) 2.4″ (62mm) 5.2″ (132mm)
Pro-Line Chisel 1.9 1.9″ (48mm) 1.46″ (37mm) 3.72″ (94mm)
Pro-Line Flat Iron 1.9 1.9″ (48mm) 1.52″ (38mm) 4.20″ (106mm)
Pro-Line Interco TSL SX Super Swamper 1.9 1.9″ (48mm) 1.50″ (38mm 4.30″ (109mm)
RC4WD Crazy Krawler 1.9 Tires 1.9″ (48mm) 1.42″ (36mm) 4″ (101mm)
RC4WD Dick Cepek 1.9 Mud Country 1.9″ (48mm) 1.54″ (39mm) 3.97″ (101mm)
RC4WD Dirt Grabber 1.9″ 1.9″ (48mm) 1.47″ (36mm) 3.8″ (96mm)
RC4WD FlashPoint 1.9 Military 1.9″ (48mm) 1.4″ (35mm) 4.2″ (106mm)
RC4WD Mud Plugger 1.9 1.9″ (48mm) 1.2″ (30mm) 4.06″ (103.25mm)
RC4WD Mud Slingers 1.9″ 1.9″ (48mm) 1.42″ (36mm) 3.66″ (93mm)
RC4WD Mud Thrashers 1.9 1.9″ (48mm) 1.47″ (36mm) 3.9″ (99mm)
RC4WD Out Croppers 1.9 1.9″ (48mm) 1.45″ (37mm) 3.82″ (97mm)
RC4WD Prowler XS Scale 1.9 1.9″ (48mm) 1.34″ (34mm) 3.78″ (96mm)
RC4WD Rock Creepers 1.9 1.9″ (48mm) 1.45″ (37mm) 3.8″ (95mm)
RC4WD Rock Crusher II X/T 1.9 1.9″ (48mm) 1.50″ (38.3mm) 4.33″ (110mm)
RC4WD Rock Crusher X/T 1.9 1.9″ (48mm) n/a 4.25″ (108mm)
RC4WD Rock Stompers 1.9 1.9″ (48mm) 1.56″ (39.5mm) 4.17″ (106mm)
RC4WD Rok Lox 1.9 Comp 1.9″ (48mm) 1.75″ (45mm) 4.5″ (114mm)
RC4WD Tomahawk 1.9 1.9″ (48mm) 1.47″ (36mm) 3.9″ (99mm)
RC4WD Trail Buster Scale 1.9 1.9″ (48mm) 1.14″ (29mm) 4.09″ (104mm)
RC4WD Two Face 1.9 Offroad Scale 1.9″ (48mm) 1.77″ (45mm) 4.48″ (114mm)
RC4WD X-Lock Crawling 1.9 Comp 1.9″ (48mm) 1.41″ (36mm) 3.83″ (97.5mm)
2.2″ Tires
Axial 2.2 Rock Lizards 2.2″ (56mm) 2.2″ (56mm) 5.2″ (132mm)
Hot Bodies Rock Grabber 2.2 2.2″ (56mm) 2.2″ (56mm) 5.1″ (130mm)
Hot Bodies Rover 2.2 2.2″ (56mm) 2.2″ (56mm) 5.5″ (140mm)
JConcepts Rocx 2.2 2.2″ (56mm) n/a n/a
Pro-Line Badlands 2.2 2.2″ (56mm) 2.07″ (53mm) 5.06″ (129mm)
Pro-Line Chisel 2.2 2.2″ (56mm) 2.3″ (58mm) 5.4″ (136mm)
Pro-Line Flat Iron 2.2 2.2″ (56mm) n/a 5” (127mm)
Pro-Line Hammer 2.2 2.2″ (56mm) n/a 5” (127mm)
Pro-Line Masher 2000 2.2″ (56mm) n/a n/a
RC4WD Crazy Krawler 2.2 2.2″ (56mm) 2″ (51mm) 5.25″ (133mm)
RC4WD Dune X/T 2.2 Off-Road 2.2″ (56mm) 1.45″ (37mm) 4.29″ (109mm)
RC4WD Gauntlet Scale 2.2 2.2″ (56mm) 2″ (51mm) 4.84″ (123mm)
RC4WD Hollowpoint Scale Comp 2.2 2.2″ (56mm) 1.92″ (48.75mm) 5.28″ (134mm)
RC4WD Intimidator 2.2 Formula Offroad 2.2″ (56mm) 2.2″ (56mm) 3.7″ (94mm)
RC4WD MIL-SPEC ZXL 2.2 2.2″ (56mm) 1.84″ (47mm) 5.17″ (131mm)
RC4WD Mud Slingers 2.2 2.2″ (56mm) 2″ (51mm) 4.88″ (124mm)
RC4WD Out Croppers 2.2 2.2″ (56mm) 1.96″ (50mm) 5.31″ (135mm)
RC4WD Rock & Die Scale 2.2 2.2″ (56mm) 2″ (51mm) 5.5″ (140mm)
RC4WD Rock Crusher X/T 2.2 2.2″ (56mm) 2″ (51mm) 5.5″ (140mm)
RC4WD ROCK STOMPERS 2.2 2.2″ (56mm) 2″ (51mm) 5.5″ (140mm)
RC4WD Rocklin Crawling 2.2 2.2″ (56mm) 2.16″ (55mm) 5.35″ (136mm)
RC4WD Rok Lox 2.2 Comp 2.2″ (56mm) 1.61″ (41mm) 5.35″ (136mm)
RC4WD Spooky Krawler 2.2 2.2″ (56mm) 1.77″ (45mm) 5.15″ (131mm)
RC4WD X-Lock Crawling 2.2 Comp 2.2″ (56mm) 2″ (51mm) 5.5″ (140mm)
Team Integy ERC2 2.2″ (56mm) n/a n/a
Team Losi Boss Claws 2.2 2.2″ (56mm) n/a 5.35″ (136mm)
Team Losi Comp Claws 2.2″ (56mm) n/a 5.2″ (132mm)
Team Losi Rock Claws 2.2 2.2″ (56mm) 2.2″ (56mm) 5” (127mm)
Hot Bodies Sedona n/a n/a n/a
HPI Rock Grabber n/a n/a n/a
Panther Cougar n/a n/a n/a
Nice layout. Easy to read. Great work! I did notice that the pitbull tires are not listed. Also the proline 1.9 tsl
Xl needs to be added to the list.
