Who's got them?
Thoughts? Quirks/Issues?
Got a set on the way for the TK/Blazer that should be here end of week.
Gonna build a full axle around them and swap it out with the one out of the kit.
Then the front axle currently installed will get a diamond pumpkin along with the r SSD axle I have and they'll be going in the box as I get ready to do a full out class 3 build. Think I'll get a Pheonix Tranny for it and go from there.
Anyways, was wondering if anyone else has a set and your thoughts.
The axle is going to be a near copy of the stock one with 2 differences.
Pro44 pumpkins with metal retainer rings, metal axle tubes, metal chubs etc. The 2 differences in the new axle going in will be the scale lock out hub setup, and installing the bass knuckles to add a bit of weight.
Did grab a set of +3 hexes with rotors for the rear as the lockout setup add a little width to the front. I wanted to match it on the rear. Should help stabilize it a bit as shes a bit top heavy with the Blazer body and then the roll cage.
