Scale Crawler Picture Archive (PICTURES ONLY!)
Truck Base : SCX10 II
Body: Toyota Hilux
ESC: Axial AE-5
Motor(s): 45t Axial
Servo(s): Hitec 7950TG
Trans:Scx
Axles:Wraith
Tires:2.2" Jconcepts
WB:12.5"
Overall Width:12"
Diff clearance: 1 3/4"
Center Chassis clearance:4"
Overall height:11"
Weight:11 lbs IMG_10.jpg
Juggernaut
Just finished the bomber build!!
Truck Base : Wraith
Body: Aluminum Panels
ESC: HH BR-XL
Motor(s): HH 30T TorqueMaster Expert
Servo(s): Hi-Tec HS-7954SH
Trans: Hot Racing
Axles: RC4WD Aluminum AR60
Tires: Pitbull RockBeast II's
WB: 14.5"
Overall Width: 11.75"
Diff clearance: 1.85"
Center Chassis clearance: 2.54"
Overall height: 9" to top of lightbar
Weight: 9.2 lbs with 3s 5000mah LiPo pack
Truck Base : AX-10
Body: Trail Finder 2 Cab; Rear Wraith metal cage grafted to AX-10 chassis
ESC: HH BR-XL
Trans: Hot Racing; All metal gears
Axles: AR60
Tires: Axial BFG's (at the moment)
WB: 12.7"
Overall Width: 11.35"
Diff clearance: 1.65"
Center Chassis clearance: 2.35"
Overall height: 8.65"
Weight: 8.7 lbs with 3s 5000mah LiPo pack
Ax10 deadbolt
Hot racing 2.2 wheels
Chinese chevrons
Castle ESC with 2650 KV motor
MIP shafts
15T pinion
3S only
Truck Base : SCX10 Deadbolt
Body: 1/6 New bright Dodge Ram
ESC: Stock AE-5
Motor(s): Axial 35t
Servo(s): ProTek RC 100T
Trans: Stock AX10 w/steel gears
Axles: AR60s will be under driving rear
Tires: 2.2 Hyrax on Jazrider aluminum wheels
WB: 15 inches
Overall Width: (I'll update after measuring)
Diff clearance:?? (I'll update after measuring)
Center Chassis clearance: (I'll updated after measuring) Has Vader products trans skid.
Overall height: (I'll update after measuring)
Weight:(I'll updated after weighing)
Snow wheeling the wroncho dodge with 2.8
*SCX10 Wrangler*
Body: Stock Axial Wrangler body
ESC: AE-2 with castle link
Motor(s): Axial 27t
Servo(s): HiTec HS-9750TH
Trans: Stock SCX10 trans with heavy duty gears
Axles: Stock SCX10 axles with upgraded metal knuckles and ends
Tires: Proline Flat Iron 2.2
Wheel Base: 12"
Overall Width: 9 1/2"
Diff clearance: 1 7/16"
Center Chassis clearance: 3 1/8"
Overall height: 9 1/2"
Weight: 7lbs
Extra: Custom aluminum 4-Link and steering linkage, fully waterproofed to drive completely submerged, Gear Head aluminum Slot Mag 2.2 real beadlocks, Incision metal drive shafts front and rear, heavy duty axle gearsets, 100mm King shocks, and fender liner.
*SCX10 II Cherokee*
Body: Stock Axial Cherokee
ESC: AE-5 with castle link
Motor(s): Axial 27t
Trans: Stock SCX10 II Trans with heavy duty gears
Axles: Stock SCX10 II axles
Tires: Proline 2.2 BFG AT KO2's
Wheel Base: 11 7/8"
Overall Width: 9 5/8"
Diff clearance: 2"
Center Chassis clearance: 3 9/16"
Overall height: 11 1/4"
Weight: 6lbs 13oz
Extra: Fully waterproofed to drive completely submerged, interior and roll cage from SCX10 Wrangler body, Gear Head aluminum Slot Mag 2.2 real beadlocks, and 100mm King Shocks. Fended liner has also been added after pictures were taken.
My 3 2.2s
The Wraith just got a new body and wheels. The Bomber is waiting on new front and rear axles, new wheels and tires are on the way. The Yeti is getting new lights eventually.
Make : SCX10 II
Body: 2017 Jeep Wrangler
ESC: Stock
Motor: YR 550 35t
Servo(s): Amazon special 23kg
Trans: Stock
Axles: SSD Diamond w/ front brass shock mounts/Rear wraith shock mounts that curve over the axle tube
Tires: 2.2 XL Proline TSL Super Swampers
Wheels: 2.2 Axial 8 hole beadlocks with steel beadlock ring and CI foams
Links: RC4WD Rock Krawler links front/rear. Fronts are for extended length Wraith
WB:12.4"
Overall Width:12"
Overall height:12"
Truck Base: Integy iRock-10 V3 edition
Body: HPI MT Baja Bug
ESC: Duratrax Blast
Motor(s): Integy 55t
Servo(s): Stock B7018 Integy
Trans: Stock Integy
Axles: Stock Integy
Tires: 2.2" Duratrax Approach CR
WB: 12.5"
Overall Width: 10.5"
Diff clearance: 2"
Center Chassis clearance: 3.5"
Overall height: 9"
Weight: 5.5 lbs.
Sent from my SM-G965U using Tapatalk
