Scale Crawler Picture Archive (PICTURES ONLY!)
Cut down jk body
Full exo
swampers etc..
Here are the updated pictures of my SCX10 with the Rock Chisels on Epic Wheels.... Sorry the pictures are from my cell phone.
CR01 Blazer on 2.2 mudslingers
here is my tamiya CR01 stretched a bit sittin on 2.2 mudslingers and K5 blazer.[thanks for the tires NorZepol]
WIP 2.2 jeep cj check it serch metal body 2.2 jeep build
Truck Base : POS peices of steel :ror:
Body: POS peices of steel
ESC: novak xrs with dielectric grease
Motor(s): itegy 45
Servo(s): traxxas 2055 ??? with dielectric grease
Trans: ax10
Axles:ax10
Tires:ax10 kit rock lizerds siped all up
WB: 12.0
Overall Width: 10.25
Diff clearance: 1.25
Center Chassis clearance: 3 :ror:
Overall height: 10.25
Weight: 9 lb?? or so
The Bettformer
Truck Base : ax10 kit and POS peices of steel :ror:
Body: half of a betty
Motor(s): itegy 45
Trans: ax10
Axles:ax10
WB: 12.5
Center Chassis clearance: idk
Overall height: idk
Weight: 8 lb?? or so
670 stretchluse
Body: custom strectched wreckluse
ESC: traxxas velineon
Motor(s): 21.5 turn novak ballistic brushless (sensorless)
Servo(s): hi-tec 7955
Trans: ax10
Axles:ax10
Tires: TSL Swampers
WB: 15 1/4"
Overall Width: 12"
Diff clearance: 2"
Center Chassis clearance: 3"
Overall height: 10"
Articulation: 7" bottom of tire to floor
Weight: idk
Truck Base : wreckluse
Body: jeep
ESC: sidewinder
Motor(s): tekin
Servo(s): hitec
Trans: axial
Axles: axial
Tires: Rc4wd interco boggers
WB: 12.75
Overall Width: 9 "1/4
Diff clearance: 2"
Center Chassis clearance: 4"
Overall height: 10.5"
Weight: unknown
SCX10
Velineon VXL-3s Brushless Power System
Pro-Line Titus 2.2" Black/Black Bead-Loc wheels
Pro-Line Power Stroke Scaler Shocks
MIP Spline Center CVD
Hand Brothers CMS Steering Kit
Robinson Racing steel gears
4x4 with 2dr jk on 2.2's
Just wanted to post the New Body. "thumbsup"
<a href="http://s1198.photobucket.com/albums/aa441/dinobomb3/?action=view&current=P7210885.jpg" target="_blank"><img src="http://i1198.photobucket.com/albums/aa441/dinobomb3/P7210885.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1198.photobucket.com/albums/aa441/dinobomb3/?action=view&current=P7210881.jpg" target="_blank"><img src="http://i1198.photobucket.com/albums/aa441/dinobomb3/P7210881.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1198.photobucket.com/albums/aa441/dinobomb3/?action=view&current=P7210886.jpg" target="_blank"><img src="http://i1198.photobucket.com/albums/aa441/dinobomb3/P7210886.jpg" border="0" alt="Photobucket"></a>
Truck Base : SXC10 Honcho
Body: New Bright 4 door J/K chopped up and made into a brute
ESC: HH BR-XL waterproof
Motor(s): HH 10T Puller
Servo(s): Savox SC1257TG for front steer, Hitec HS 5645MG for rear steer, HS 645 MG for winch
Trans: Axial with all robinson's internals and 32P 56/20 Spur/Pinion
Axles: Axial will aluminium CHus and Knuckles and overdrive
Tires: 2.2 Proline TSLs
WB: 13.5"
Weight: 10+ LBs
Heres a new tuber I've been working on...
Ax10 axles and trans, 2.2 TSLs, 27t motor, rubi front, 4WS
PM me for any extra info or a build should be done...
