Scale Crawler Picture Archive (PICTURES ONLY!)
2.2 Roc Lox with 110mm shocks for lift so I could leave the body where it needs to be. Minor trimming and it all works great.
Axial AX10 Scorpion ARTR
Carbon fiber chassis
Rooster ESC
Integy 55t motor
STRC aluminum hub carriers, turnbuckles and bottom plate
Integy internal spring shocks
Futaba hi tourque steering servo
Defender 90 In Yosemite, CA
CR-01
Landrover Defender 90
Goat
DX3R
Losi Shocks
HT Servos front and rear
Droop Set-up
Tire - Hammers
Rims - Stock with 1lb each fronts and .5 rear each
Defender 90 in N.Shore Hawaii
Cr-01
Defender 90
Goat
Dx3R
Losi shocks
hT -Front and rear servos
Droop Set-up
Alot of weights on from and rea rims (2lbfront and 1lb rear)
My HPI Land Rover
HPI WK, with Rovers, CC sidewinder, 55T integy, running 15T pinion/96T spur, 3s lipo, hitec 645 servo, will be mounting a rack on rear lid and some lights too.
Truck Base : Custom Tube Chassis
Body: Toyota Hilux
ESC: Tamiya
Motor(s): 55 Lathe
Servo(s): Futaba Digital Servo
Trans: R2 trans
Axles: Tlt
Tires: 2.2 Moabs
WB: 12"
Overall Width:
Diff clearance:
Center Chassis clearance:
Overall height:
Weight: its a pig.
Here is my 2.2 with the Betty Body. The 2.2 tires look good with the body.
Truck Base: SCX10
Body: Hummer H2T
ESC: Tekin FXR
Motor: Tekin 55T Pro-Hand Wound
Servo: Axial AS-2
Trans: Stock Axial AX10
Axles: Stock Axial AX10
Tires: RC4WD 2.2 Mudslingers
picture.php
picture.php
picture.php
Shassis kit: Tcs X-trail
Truck Base :axial ax-10
Body:Proline ambush cgr
ESC:Novak rooster crawer
Motor(s):40T
Servo(s):??
Trans:ax-10
Axles:ax-10
Tires:Proline flat iron
WB:??
Overall Width:??
Diff clearance:??
Center Chassis clearance:??
Overall height:??
Weight:3.7 kg(8.2 lbs)
scaleax10_01
scaleax10_02
scaleax10_03
scaleax10_04
scaleax10_05
scaleax10_06
scaleax10_07
scaleax10_08
scaleax10_09
scaleax10_10
