Sanford Boat Ramp SORRCA Event???
AsILayDying
Orlando
Well after todays fun under the bridge in Sanford Im gonna try and guage interest in having a SORRCA Event. It will follow all guide lines as stated below. If you are interested please reply to this post and I will update with a member list. As of this moment there is no specifics set. We can all discuss a date that works for everyone as much as possible. (we cant make everyone happy, but I will try) The next few weekends I will be going out there to have fun and crawl a bit but also be bringing a machette to clear the trail area so there will be some great video spots as well as great camera areas. So far it seems we have some people who are interested and can only get better with more scale rigs (Matt this means you..... :lmao:) Met a few people out there today that seem to be real cool and well worth the effort to make a great scale spot for us to enjoy. The below information are the rules we will be following. Any questions or information and or advice would be appreciated. "thumbsup"​
SORRCA
Scale Off Road RC Association
2011 Official Scale Rock Crawling Competition Rules
Introduction:
This rulebook is intended to standardize scale off road RC competitions that are held at various locations throughout the world. The intention is for all clubs/events to use these rules as written; however, they may be modified on a local basis. Any and all changes made to these rules at a SORRCA sanctioned event must be covered in a preliminary drivers meeting and publicly posted before the event.
Class Descriptions
Class-1 “Street"
• Description - A Street Legal off-road vehicle that you would drive to work and the trail head and outfit like an expedition vehicle such as the Camel Trophy truck D90 rigs.
Class-2 “Trail”
• Description - A stock vehicle that has been modified to become a capable trail rated rig and is not necessarily street legal .
Class-3 “Modified”
• Description - An off-road vehicle that you would build from the ground up and might see in a TTC/KOH type competition.
General Vehicle Details
• You are encouraged to go above and beyond to make your truck as scale as possible
• Vehicles must resemble a real 1:1 rig and it will be up to the collective group to vote on whether a questionable rig is accepted or not.
• Tire size will be determined by advertised manufacturer specs. (tires without available specs will be measured off the truck as mounted on the wheel laid flat)
•Tire modification:
Class-1 Street. No tire modification is allowed.
Class-2 Trail. Tire lugs may be removed, sipped, grooved and/or trimmed.
Class-3 Modified. Tire reduction and narrowing is permitted, as well as all modifications listed above.
• You must run a rail chassis (for example: Bruiser/Mountaineer, SCX-10, Reign RC K2-3S, 3L, 4, 5, MFM, X-Trail, CR-01, UTE, etc...) No TVP (twin vertical plate) chassis' or frame rail extensions on a TVPs. The exception to this rule is the Tamiya CC-01 or TA-02 ,(Hummer, S-10, Ford F-150 and Toyota Hilux)and Modified class Tubers.
• 4 wheel steering or dig is allowed in modified class only (must choose 1 per course)
• No "Motor On Axle" (MOA) of any kind. Your axles must be driven by one transmission or transfer case and a minimum of two drive shafts (except CC‐01, TA ‐02 etc..). No separate throttle control of drive shafts or axles.
• There are no Wheel distinctions. For example you can run a 1.55, 1.9, 2.0 or 2.2 rim in any class. Wheels larger than 2.2 are not allowed in any class and no Short course style wheels 1.9/2.2 split diameters
• Spare Tires must be within 1/4" Diameter of Drive tires to receive points
• Any functional recovery tools you wish to use during your run, you must carry it on your rig at all times. IE tow strap, pull pal and, sand ladders.
• Winching can only be performed off of natural objects (i.e. trees, rocks, ect...), other vehicles or stakes supplied by the course maker. Winching off of a person such as there shoe or hand is not allowed.
• All vehicles without an enclosed cab must have the motor, transmission, and electronics covered and hidden when viewed from the top and sides. Batteries must be chassis mounted and also hidden from view.
• Course will be tough and made to push the scale vehicle limits. This is to encourage competitors to improve there rigs from one event to another.
• Winches are HIGHLY recommended!!!!! Expect to use a winch.
• Water proofing is HIGHLY recommended!!!!! Expect your rig to get wet.
Tire Ban List
• Losi Claws (all sizes, and types)
• Hot Bodies Rovers (all sizes)
• Hot Bodies Sedonas
• HPI Rock Grabbers
• Panther Cougars
• Panther Leopards
• Pro-Line Chisels (all sizes)
• RC4WD Rocklin
• RC4WD X-Locks (all sizes)
• RC4WD Crazy Crawlers
• Imex Skulls and Bones
• Losi Bashers
Tires should be scale appearing, if it is questionable have it reviewed before the event, or plan to run a different tire. As new competition specific tires are released this list may be updated.
Class-1 “Street” Details
• Vehicle must have a windshield that fills the entire windshield frame
• Full width bumpers are required on the front and rear of the vehicle. Bumpers that are molded into the body qualify. A rear bumper is not required on a flatbed, but adding one to the flatbed will gain the additional scale points. (Bumpers are measured from the outsides and must be the width of your windshield).
• Wheels must be aligned within the body wheel wells (center of wheels to center of wheel wells +/- 1/2 inch total combined)
• The vehicles body must be mostly intact. Mild trimming such as flairs & removing a hardtop allowed only. If hardtop is removed full interior is required. (no extreme trimming of bodies allowed See below.)
• The tread of the tires cannot extend outside of the wheel wells more then 1/2 of the tread width, flairs can be added to reach min. spec.
• Vehicle must run a full length rail chassis (The rail chassis must be as long as the vehicles wheelbase)(Tamiya CC-01 Chassis are allowed)
• Truggies are not allowed, flatbeds with full length rail chassis are allowed. The bed must be as wide as the cab the entire length of the bed. Cab only not allowed.
• Tires can never extend beyond the body’s bumpers or the rear of any truck bed. (Any stingers, fairleads, shackles, bolts, etc are not considered part of a bumper when determining this.)
• Dovetailing is not allowed.
• Sectioning or narrowing of the body is not allowed.
• Bobbing a truck bed is allowed, but must follow All body specs
• Boat sides are not allowed.
• 106mm / 4.19" Max tire size including spares
• Gates will be a minimum of 11" wide (so mind your width)
Class-2 “Trail” Details
• The inside of the front tires cannot extend outside of the width of the cab at the doors
• The body (including bumpers) must be 3" longer than the wheelbase
• A front bumper is required and must be mounted to vehicles rail chassis and wider the the chassis (chassis cross rails do not count as bumpers)
• Vehicle must run a full length rail chassis (The rail chassis must be as long as the vehicles wheelbase extensions are legal for bumpers as long as the chassis meets other specs)
• Truggies are allowed, but must have a rail chassis up too the rear of the skid minimum. The truggy structure must extend to the back of the rear axles pumpkin or beyond to be legal.
• Flatbeds that run the full length of the rail chassis are allowed. The bed must be as wide as the cab the entire length of the bed.
• 2 of the 3 following modifications are allowed
- Dovetailing the rear (a truggy/tube bed that is narrower than the cab counts as dovetail).
- Boat sides (no more then 1" measured vertically)
- Pinching the front (2/3 the width of the widest part of the cab)
• Body / Cage work must be at least 4.5" tall (including boat sides) and wider then the inside measurement of the vehicles track width (front or rear, whichever is wider).
• 120mm / 4.75" max tire size with a 2.2 max rim size including spare
• Gates will be a minimum of 12" wide (so mind your width)
Class-3 “Modified” Details
• 146mm / 5.75" max tire size with a 2.2 max rims size including spare
• A bumper is not required, but to be counted for points, must be mounted to vehicles chassis and wider the the chassis (chassis cross rails do not count as bumpers)
• Gates will be a minimum of 13" wide
• All bodies (Including tubers) must measure a minimum of five inches wide from front to rear of door, measure a minimum of 4.5 inches tall as measured from the skid to the tallest point on the body and must be as long as the vehicles wheelbase
• Body modifications including, but not limited to, pinched front, dove-tailing and boat-siding are permitted as long as the final dimensions comply with the minimum size rules.
Scale Points
Scale points are to be awarded on a per course basis at 50% of a vehicles total value (rounded down if necessary).
Minimum/Maximum values are to be determined by the event organizers.
Bed :
• Tube bed OR Flat Bed: metal -3, plastic -1
• Bed mounted headache rack or roll bar: metal -2 Plastic -1
Truggy & back halved truck
•Truggy/back halved truck: metal -4, plastic -2
(Must replace the ladder frame from the rear of the skid Min. to the back of the rear axles pumpkin or beyond to be legal.. Must have a roll bar hoop. Must have integrated shock mounts. Must be a structural part of the rear of the vehicle. (If your bed does not meet ALL of the preceding criteria, it does not count as a truggy bed)).
Tuber: metal -8, plastic -4
A tuber consists of a complete body structure where the front, cab, and rear sections are comprised entirely of structural tubework.
• Rigid Metal/plastic body panels -1
Interior cage or exo-cage: (-3 metal -1 Plastic) per row of seats protected. (Must have down bars and cross bars in front & behind each row.)
Tube accessories
• Sliders: (both sides) metal -3, plastic -1
• Tube fenders: Metal -1 per pair
• Integrated tube shock mounts: metal -1 (per pair)
Body
• Hard body: full -8, Cab -4
• Drop bed : -3
• Complete Custom built body: (metal or hard plastic, no lexan) full -4, Cab -2 (in addition to hard body points)
• Inner fender wells: -1 per pair
Bumpers (items must be chassis mounted and separate from the body)
• Bumpers : metal -3 each , plastic -1 each
• Stinger/grill guard: -1
• Spare tire carrier (must be bumper mounted): -1
Exterior roof rack / light bar (may only choose one)
• roof rack: metal: -2, plastic -1
• Roof top light bar : metal -1
Interior:
• 3D interior: 2 seat -3, 4 seat -4, SUV cargo area -1.
• 2D/half interior: 2 seat -1, 4 seat -2.
• Realistic Scale Human figures: full(knees up) -2, part -1(torso up) (max 2 figures)
Suspension/Drive train/Steering:
• Leaf springs (front/rear): -3 ea, -7 both.
• Multiple axles: 3 driven axles -3, 4 (or more) driven axles -5
• Chassis mounted steering servo: -5 (front) rear -2 (Class 3 only)
• Transfer case: -4.
• 3D engine: -4.
Realistic exterior items (max -6 pts): Items that are non functional but you would see on a trail truck
• Fuel cell, exhaust, jerry can, hubs on all wheels, steering stabilizer, disc/drum brakes on all wheels, mirrors(2), wipers(2), antenna, license plate, Fire extinguisher, trail tools (Hi-lift jack, etc.)first aid, Etc. -1 each
Functional items (max -8 pts):
• Tow strap, -D-ring, Pull Pal, sand ladder, hitch, Etc. -1 each
• Headlights(2) and taillights(2) -2
• Winch -2 Each
• Full size spare tire. -3
Event Rules
SORRCA is proud to release the 2011 seasons course points and penalties. We appreciate everyone's patience with us as we finished these up. We as a committee decided for the 2011 season, to leave point outs up to the clubs. We do suggest that clubs use a a point out value range between 60-80 for a max point out.
Course points and Penalties
Points
Progress: -2 points
Reverse: 1 point
Gate Marker: 10 points
Rollover: 5 points
Boundary Marker: 10 points
Vehicle Touch (Repair & Repositions): 10 points
Course Direction: 10 points
Winch: 1 point
Assisted Recovery: 10 points
Dig/Rear steer: 5 points
Did not finish point out +20 points
Did not start point out +50 points
Back Up/ Reverse: (1 pt) point is given when a vehicle reverses course after making forward progress. Reversing is defined as at any time if any of the tires move the vehicle backward or spin in the reverse direction, whether engaged or in freewheel and/or whether intentional or not. Once a reverse penalty is given, no further reverse penalty can be given until the vehicle makes forward progress. No penalty is given if the backward movement is part of a penalized rollover. If a driver begins a course in reverse, a reverse penalty will occur immediately.
Rollover: (5pts) Points are given when a vehicle rolls over and cannot be corrected without touching. Once the vehicle has stopped it may be rolled back onto it's wheels and a 5 point penalty shall be given. Vehicles that land back on their wheels without assistance are not penalized. No reverse penalties will be awarded until the vehicle is righted. The vehicle may at no time be lifted, slid or moved in any way other than a smooth, continuous roll to the left or right side only. Any other manipulation or movement of the vehicle will be considered a Vehicle Touch.
Vehicle Touch: (10 pts) All vehicle touches excluding “Rollovers”, "Winching", "Assisted Recoveries"(see associated rules) , intentional or unintentional, are given an automatic 10 points. The judge then will stop time when either the driver calls for a vehicle touch or the judge calls a driver touch. The vehicle is then moved back by the driver to the previously cleared gate with the rear axle aligned to that gate. If the vehicle cannot be aligned to the gate due to course design, the judge will reposition the vehicle to the next stable location after the cleared gate. This location will be used for all drivers. Note: All gates for progress are still “live” unless a gate has already been deemed “dead”.
Vehicle Touches: include but are not limited to: repairs, repositions, vehicle driving/falling into the driver.
On Course Repairs: (Touch 10pts) Must be completed on course and in the spot of which the driver decided to take the repair. Repairs must be made within the course time, while the course timer will continue to run. If repairs are made
within the course time the driver must return to the last previous gate cleared. If repairs cannot be made within the course time, the driver is given a DNF minus progress points for that course. There are no restrictions on whom or how the repairs are made.
Off course repairs: (Touch 10pts) A driver can call time to make an off course repair. Repairs should be completed within 30 minutes, or the driver is given a DNF minus progress points. If the repair is made in the
allotted time the driver must return to the last previous gate cleared. A 1 minute time penalty will be subtracted from the time that is left on that course, the timer will continue once the vehicle makes forward progress
Reposition: (10 pts) the vehicle will be placed with it's rear tires in the last gate progressed or ,the nearest stable location after the last cleared gate if the last gate cleared is unstable.
Gate Marker: (10 pts each) each gate will be comprised of 2 gate markers. Points are given when all wheels do not travel between gate markers or any part of the vehicle, driver, a tow strap or winch line touches a gate marker. A gate marker will remain "live" for the entire duration of the attempt on the course. Once any gate marker has been touched or straddled, no more penalties will be given for that gate marker. Only when a gate penalty is assessed will that gate marker be deemed "dead". No further penalties will be assessed at this point for that gate marker.
Boundary Marker: (10 pts each) Points are given when any part of the vehicle touches a boundary marker. Once a boundary marker is touched the judge then will stop time, and the vehicle is then moved back by the driver
to the previously cleared gate with the rear axle aligned to that gate. If the vehicle cannot be aligned to the gate due to course design, the judge will reposition the vehicle to the next stable location after the cleared gate. This location will be used for all drivers. A boundary marker will remain "live" for the entire duration of the attempt on the course, and should be replaced if moved. Boundary markers are not required in the design of a course.
DNF (Did Not Finish): (Point out +20 pts) are given anytime a driver cannot complete a course for any reason. (Time expired, Point-Out, Vehicle not repairable, Went Home …etc) Progress points are awarded for each gate completed and Scale points are awarded.
DNS (Did Not Start): (Point out +50 pts) are given anytime a driver cannot start a course for any reason. Vehicle must start course under its own power. No Scale points will be awarded to this course.
Progress bonus: (-2 progress point) shall be awarded to drivers for each gate that is cleared by the vehicle during the attempt of a course. A gate is considered cleared and a progress bonus shall be given when at least one front and one rear tire passes completely through the gate in the intended direction of the gate. All tires must pass completely through the gate to receive the progress bonus without a gate penalty. A 10 point gate penalty shall be given if all tires do not clear the gate, even if no gate marker is touched or straddled. The tires of the vehicle must travel completely through the gate, and not just break the plane of the gate. Tires must pass through the gate in the same direction and in the same attempt before a progress bonus is awarded. These points are deducted from the total course score. Once a driver has pointed out, no further Progress Points will be awarded.
Course Direction: (10 pts) Gates must be cleared in their intended direction and sequence. Any part of the vehicle entering an non-cleared gate in the wrong direction, or driven through out of sequence will result in a 10 point penalty. The judge will stop time. The vehicle is then moved back to the previously cleared gate (see reposition rule) Once the gate is cleared and awarded progress it can be traveled in any sequence or direction.
Winching: (1 pt each) A winch penalty will be assessed every time the winch cable is connected for a pull. If the winch line comes unhooked during a pull, or a 2nd attachment is needed, another penalty will be assessed. If at any time during the process of removing recovery tools and/or winch line from vehicle, the vehicle is moved by any force other than it's winch or it's own power, a touch penalty will be assessed and the vehicle repositioned to the last cleared gate (see Vehicle touch rule).
Assisted Recovery: (10 pts) At any time during the course, a driver may call for an assisted recovery. With the clock running, another vehicle will be brought onto the course to pull or winch the stranded vehicle to safety. The stranded vehicle shall not be pulled beyond the original position of the rescuing vehicle or it will result in another Assisted Recovery penalty.
Dig/Rear Steer (Class 3 only): (5 pts) Dig and rear steer are both legal in Class 3, but only one may be used per course. The first use of dig or rear steer will incur a +5 point penalty; subsequent uses of the same feature (dig or rear steer) on the same course are free. Use of the other feature is prohibited. If at any time on the same course the driver uses rear steer after using dig, or uses dig after using rear steer, a reposition penalty will be incurred, and the truck will be placed at the last cleared gate.
Safety Time Out: A driver may call for time to stop so that he or she may safely reposition themselves on the course. This time shall be used for the purpose of driver safety and may not be used to survey the course or for any other advantage. Once the competitor is repositioned the time will start, however the judge has the right to start time at any point.
Vehicle Out of Spec: If the Judge has reason to believe a vehicle is out of spec during a course run, he may call time to stop. At that point no additional inputs maybe given by the driver to the vehicle via touch or radio
control. The Judge must mark the vehicle’s location and perform a tech inspection in the specified tech area (same manner as all other tech inspections). If the vehicle has been deemed within spec, the driver and vehicle will return to the location marked by the judge and the clock will start once again. If the vehicle is now out of spec and the Judge has determined that the vehicle has gained an advantage, the driver must take a repair to correct the problem. If the problem can not be corrected to bring the vehicle back within spec, the driver will receive a DNF for that course. If a vehicle falls out of spec due to breakage on course and the Judge determines the driver has not gained an advantage, then the driver may be allowed to continue on course without stopping time and requiring a tech inspection. Bodies, and body panels are not included in this exception, and must be replaced immediately, standard repair procedures and penalties apply.
__________________
sounds good to me, but i have two wheely kings (tvp chassis) that might change by the time youre going to do this. just wondering what class the wraith would fall into if any. i was thinking the 3rd class but not sure.......didnt read all the rule.
this sounds really technical :mrgreen:
I could fall into class 1 if I just put some unmodified tires on my rig, since I trimmed every other outer lug off my flat irons
but yeah this sounds like a really killer idea! I see myself making more frequent trips down to Casselberry in the future "thumbsup"
Can a bathtub type chassis be used in this class?
The way i read that is the chassis must be a rail type, I.E. Like the SCX 10 or a aftermarket frame in all but Class 1.
This is the Class 1 chassis rule:
Yeah its not too clear to me speedracer19, In class 1 it metions the CC01 but in general details it says the TA-02 is an exception, I wonder what class it has the exception in?:x hopefully any of them.
It's clear, you would have to build your rig to the Class 1 details (Which you can use a "Tub" type chassis). If you were going to run a Class 2 rig then you would have to have a 2 rail chassis type. A Class 3 chassis is pretty much wide open & you can use a Tuber type chassis.
Well it looks like this may spark some interest in a few people. I know myself I'm tearing down my Rubiconcho and going back to a set of 1.9 RC4WD Mickey Thompsons, they are I believe 4.75" tall and that's the limit in class 2. My 2.2 Chisels are banned anyways so I need new tires. Got some work to do for these new comps. There is a new thread in the Florida section about SORCCA events this coming November in Mirimar. I'm down for going to this event, I'll also try and get an event held out at the boat ramp. Anyone have any other info ideas or advice let me know. I'm really wanting to start a local Central Florida crawling club. CFSC (Central Florida Scalers and Crawlers). Anyone interested just let me know.
Scalers are really taking off all over the state - I think the general lack of rock in this state has a lot to do with it.
Before starting up another club, we probably oughtta get in touch with the FSTR guys to see what they're up to these days.
I know you mean well but when you lay down to many rules people have to change alot and spend alot to make there trucks legal thats why most local spots just go by tire size to keep to keep it fun.The last comp i went to people complained that a wk had a unfair advantage yet it came in last and the winner had a brushed motor on 5s and i finished 6th with a velenion motor and speed control on 3s and its nowhere near a slow speed crawler but it goes goes like mad in the dirt,mud and sled pull.So i guess my point is keep it simple and more people will show up."thumbsup"
Dying was just reposting the established scaler rules...
Unless I missed something along the way, the whole point in what we're doing out in sanford is to have fun. I think it would be safe to say that we're using them as general guidelines for the time-being, but if we want to hold a 'sanctioned' event, we'll have to stick to SORRCA rules.
I know you mean well but when you lay down to many rules people have to change alot and spend alot to make there trucks legal thats why most local spots just go by tire size to keep it fun.The last comp i went to people complained that a wk had a unfair advantage yet it came in last and the winner had a brushed motor on 5s and i finished 6th with a velenion motor and speed control on 3s and its nowhere near a slow speed crawler but it goes goes like mad in the dirt,mud and sled pull.So i guess my point is keep it simple and more people will show up."thumbsup"
Couldnt agree more. you make it to complicated and lay down to many rules no body will show. i dont speak for everybody but i know i dont have the money anymore to buy a new set of tires at 60 bucks just to meet a class guideline. i personally like the 2.2, 1.9 and the 1.55 tire bracket classes. If and when you get the attention of the SORRCA then follow the strict-ness. "thumbsup"
