farmjohn42
Has anyone dedicated a Axial Ryft to a rock crawler vs bouncer?
For the areas I drive, the Ryft's wheelbase is a little long. I was thinking of shortening the wheelbase front and rear to keep it symmetrical in functionality. Therefore with a closer wheel base in theory there is less of a chance for the skid to hang up on the prepuce of the climb. It appears the Axial Bomber rear lower links and the upper links could match creating approximately 10mm shorter rear. The front appears more difficult with an assortment of Capra and Enduro links, it would be close if the front could be shortened a noticeable difference. I found https://www.ebay.com/itm/275356494726 front shock mounts to relocate the front shock rearward slightly to help keep some vertical correctness.
If it worked I would eventually invest in the Vivaton portals for the Ryft as well as 4WS. https://www.ebay.com/itm/284435141280
Is this too wild of a theory to work or do you think its doable or more importantly helpful?
